Large, thin shim?
Forum topic by leftcoaster posted 05-18-2017 05:45 AM 1007 views 0 times favorited 15 replies Add to Favorites Watch
View leftcoaster's profile
leftcoaster
233 posts in 1117 days
05-18-2017 05:45 AM
I’m making a chop saw stand and the side tables should be equal in height to the saw. Mine are about 1/16” too high. It looks like the easiest fix is to lift the saw to match that height. So I need something that can go underneath the saw base and provide a height gain if not more than 1/16”.
Best solution? I’m skeptical that I can rip anything that thin on the table saw. Should I use paper? Belt sand something to size? Carpet tape something to a sled and plane it?
15 replies so far
View TheFridge's profile
TheFridge
10818 posts in 1727 days
#1 posted 05-18-2017 06:00 AM
Bandsaw?
View papadan's profile
papadan
3584 posts in 3609 days
#2 posted 05-18-2017 06:03 AM
You don’t have any veneer of any kind in your shop? Or edge banding!
View OhioMike's profile
OhioMike
79 posts in 2403 days
#3 posted 05-18-2017 06:10 AM
Pick up some fender washers at the Big Box Store and place one (or two) under the saw at each bolt/screw location.
View jerryminer's profile
jerryminer
944 posts in 1682 days
#4 posted 05-18-2017 07:14 AM
plastic laminate (Formica), cereal boxes, gasket stock, sheet metal, “Handi-shims”, ....
Craftsman on the lake
2848 posts in 3678 days
#5 posted 05-18-2017 07:41 AM
Like ohioMike said, fender washers. They are large and thin.
leftcoaster
#6 posted 05-18-2017 12:30 PM
Thanks guys. This is very helpful.
View bondogaposis's profile
bondogaposis
5155 posts in 2592 days
#7 posted 05-18-2017 01:01 PM
Plastic laminate.
-- Bondo Gaposis
View Dustin's profile
Dustin
611 posts in 981 days
#8 posted 05-18-2017 01:05 PM
Used washers on mine. Part of the plan was building my miter saw slightly lower than the tables, since shimming it up is easier than hoping to get it perfect during the build.
-- "Ladies, if your husband says he'll get to it, he'll get to it. No need to remind him about it every 6 months."
leftcoaster
#9 posted 05-18-2017 01:38 PM
Dustin, henceforth I will be borrowing that line… oh yes, all part of the plan. I’ve no doubt it’s true in your case; I however will indulge in a little historical revisionism…
View mike02130's profile
mike02130
170 posts in 913 days
#10 posted 05-19-2017 11:37 AM
Pardon my snarkiness, but are you ready for a chop saw?
-- Google first, search forums second, ask questions later.
leftcoaster
#11 posted 05-19-2017 01:09 PM
Mike, sometimes the obvious is staring you in the face, unnoticed, until someone points it out to you. Perhaps you’ve never experienced that but if/when you do, I hope those around you are a bit kinder.
Dustin
#12 posted 05-19-2017 01:29 PM
Dustin, henceforth I will be borrowing that line… oh yes, all part of the plan. I ve no doubt it s true in your case; I however will indulge in a little historical revisionism…
- leftcoaster
A strategy I use frequently. I train new hires at work, and tutor on the side, and frequently point out that any perceived mistakes on my end are really just lessons in disguise ;)
mike02130
#13 posted 05-19-2017 01:39 PM
Well, you are a better and kinder man than I. Yes, I’ve been in that position many times and have been ribbed about it. As a professional woodworker it is just part of the job. It really is a blue collar thing.
My remark was not so much a diss, but more of a “just figure it out”.
Not to redeem myself, but to answer your question, the washer advice is good. If you want wood, 1, use a push block. 2, take a wider board and and cut it off the waste side, 3, and this is what I would do, set your saw to the desired shim thickness, take a board longer than you need, run it through the saw part way, bring it out and cut it with your chop saw.
leftcoaster
#14 posted 05-19-2017 01:41 PM
Mike, thanks for the suggestion.
Dustin, thanks for the laugh.
View EricTwice's profile
EricTwice
248 posts in 774 days
#15 posted 05-19-2017 02:15 PM
Fender washers and plastic laminate were my suggestions for shims.
You can drill out the feet on the saw and use 2 nuts on a bolt to make adjusters for it. that way you don’t need shims
-- nice recovery, They should pay extra for that mistake, Eric E.
