Delta 36-725 Rail Alignment
Forum topic by ErylFlynn posted 05-18-2017 12:28 AM 580 views 0 times favorited 2 replies Add to Favorites Watch
View ErylFlynn's profile
ErylFlynn
4 posts in 459 days
05-18-2017 12:28 AM
Newb here, and bought my first table saw Sunday and still trying to get it ready. Problem is like many have had, alignment of the rails. 3 of the 4 are good, but the rear right won’t go high enough. At the highest where the hole is drilled I am about 1/16th off. I see my 2 options as, drop the right rail, and shim the pad the fence tracks on, or enlarge the hole for the rail so I can raise it high enough.
If I enlarge the hole, I am thinking I should take a file to it as I do not have a rotary tool to do fine grinding.
Any suggestions on how I should move forward?
2 replies so far
View WhyMe's profile
WhyMe
1034 posts in 1641 days
#1 posted 05-18-2017 01:13 AM
Modifying the rails should be a last resort. If the fence sides are dragging on the top they have some adjustment play by loosening the bolts in the center that connects the fence sides.
ErylFlynn
4 posts in 459 days
#2 posted 05-18-2017 01:17 AM
Won’t that just make a larger gap on the left side under the fence? Yes they are dragging on the table on the right side of the table.
Are you saying forget alignment and just raise toe fence higher?
