Wiping up dust without raising grain
Forum topic by Greg posted 05-17-2017 08:20 PM 574 views 0 times favorited 6 replies Add to Favorites Watch
View Greg's profile
Greg
21 posts in 440 days
05-17-2017 08:20 PM
Topic tags/keywords: dust removal finishing prep
Hi Folks!
As detailed is some of my earlier posts, I’m refinishing a 100 year old stair rail (and newels). I’ve removed multiple layers of paint and varnish and plan to lightly hand sand it to get the final layer of color off. The only way to dertermine that I’ve sanded enough is to wipe the sawdust off to see the results. I understand wiping with water is a no-no. If I vacuum most of the dust, is wiping a cloth dampened with mineral spirits the best way to remove dust? Or alcohol? There’s a lot of answers out there on this topic, but I’m trying to see if there’s a consensus on this message board perhaps.
Thanks
Greg
View TungOil's profile
TungOil
978 posts in 550 days
#1 posted 05-17-2017 09:58 PM
if it were me, I would vacuum it and call it done. That’s all I do when I’m finishing a piece of furniture.
-- The optimist says "the glass is half full". The pessimist says "the glass is half empty". The engineer says "the glass is twice as big as it needs to be"
10476 posts in 3702 days
#2 posted 05-17-2017 10:13 PM
I prefer blowing with compressed air to
the vac, but if you don’t have compressed
air the vacuum works ok. After that wipe
down thoroughly with “tack cloth”. You
can buy it in the paint section.
View ChuckC's profile
ChuckC
829 posts in 2990 days
#3 posted 05-17-2017 10:14 PM
I always wipe with mineral spirits.
View Woodknack's profile
Woodknack
12069 posts in 2435 days
#4 posted 05-17-2017 11:21 PM
Alcohol will raise the grain.
A tack cloth is cheese cloth with a small amount of shellac.
View JBrow's profile
JBrow
1365 posts in 975 days
#5 posted 05-18-2017 01:21 AM
Greg,
I agree with Loren.
After vacuuming my projects I am amazed at how much residential dust is deposited on the tack cloth. I find several swipes of the tack cloth are needed to remove enough dust so that dust nubs are minimized after application of the first coat of finish.
View papadan's profile
papadan
3584 posts in 3423 days
#6 posted 05-18-2017 01:37 AM
In this situation I use canned air like you blow off your keyboard with, strong enough to remove all the dust and see what you have.
Hi Folks!
As detailed is some of my earlier posts, I m refinishing a 100 year old stair rail (and newels). I ve removed multiple layers of paint and varnish and plan to lightly hand sand it to get the final layer of color off. The only way to dertermine that I ve sanded enough is to wipe the sawdust off to see the results. I understand wiping with water is a no-no. If I vacuum most of the dust, is wiping a cloth dampened with mineral spirits the best way to remove dust? Or alcohol? There s a lot of answers out there on this topic, but I m trying to see if there s a consensus on this message board perhaps.
Thanks
Greg
- Greg
