Rockwell 28-200 issue
Forum topic by TheFridge posted 05-17-2017 04:18 AM 803 views 0 times favorited 9 replies Add to Favorites Watch
View TheFridge's profile
TheFridge
10814 posts in 1721 days
05-17-2017 04:18 AM
Topic tags/keywords: resource question bandsaw
Refurbing this one for a buddy
I’m not missing parts. I’ve looked up the manual on vintagemachinery.org. I’ve looked up the manual for mine (28-243).
There is a gap between the nut and the bearing. The only spacer I have or have seen required go in between the bearings. When the wheel is pushed all the way back it rubs.
Any ideas?
9 replies so far
MrUnix
7103 posts in 2433 days
#1 posted 05-17-2017 04:23 AM
What year is the saw? Older ones used 87502’s (upper wheel), which have an extended inner race. What you got there are 6202’s, which don’t. Both have the same OD and bore.
TheFridge
#2 posted 05-17-2017 04:27 AM
Not sure of the year but the extended inner race rings a bell. I’ll have to dig the old bearings up and double check but I’m pretty sure you are correct.
Well hell. I guess I’ll prob just put a washer the proper thickness back there and cal it a day if that is the case.
TheFridge
#3 posted 05-17-2017 04:50 AM
I’m pretty sure this is it.
TheFridge
#4 posted 05-17-2017 04:59 AM
.153 diff between a 6203 & 87504. That would do it. thanks man.
Edit: I looked up 6203. Durp.
MrUnix
#5 posted 05-17-2017 05:02 AM
Yup… that 87504 was on the lower wheel. Both the 87502 and 87504 are identical to their 6202 and 6204 counterparts in every way except for the width of the inner race.
TheFridge
#6 posted 05-17-2017 05:08 AM
So did I mess up twice? :)
I took pics of all the bearings and I only had one with and extended inner race. Would that one be on the wheel side facing out?
MrUnix
#7 posted 05-17-2017 05:24 AM
From the factory, that saw would either have ALL 875xx’s in it, or ALL 62xx’s in it – not a mix. And the extended races will face outwards.
Sounds like someone has been monkeying around with that machine in the past. Give Lynne a call… she will hook you up :)
View AnthonyReed's profile
AnthonyReed
10080 posts in 2675 days
#8 posted 05-17-2017 12:38 PM
Your bearings know your leanings.
-- ~Tony
TheFridge
#9 posted 05-17-2017 04:15 PM
It would make sense. They had an assortment of bearings. They also had hard bearing grease everywhere and it didn’t look like it was from the current bearings.
