Forum topic by gary351 posted 11-17-2010 09:01 PM 822 views 0 times favorited 3 replies Add to Favorites Watch
View gary351's profile
97 posts in 2728 days
11-17-2010 09:01 PM
Topic tags/keywords: question
I am making a splitter for ts, does the splitter have to be the thickness of the blade? Splitter material is 1/32 in thicker then blade.
-- A poor man has poor way's
3 replies so far
View RONFINCH's profile
143 posts in 2857 days
#1 posted 11-17-2010 09:15 PM
It’s going to be a little hard passing an 1/8th cut around a splitter that’s 1/32 of an inch wider. Splitter should be the same width as the blade.
#2 posted 11-17-2010 09:20 PM
Ok thanks ron, btw lots of sanding to do.
View Tim_456's profile
170 posts in 3528 days
#3 posted 11-17-2010 11:09 PM
take a looki at this product:
I installed that a few months ago and maybe it’ll help you. The installation was a snap and it’s just the right thickness and isn’t really all that expensive.
The splitter is (from memory), 0.001in larger than the blade on one side so that it actually pushes the cut off away from the blade but only by a small amount. It really does work nicely and I feel safer that things are not wandering back into the blade.
Good Luck!
