Arm R Seal or Waterlox . Dining table top.
Forum topic by Fax posted 05-16-2017 05:47 PM 1447 views 1 time favorited 15 replies Add to Favorites Watch
View Fax's profile
Fax
62 posts in 513 days
05-16-2017 05:47 PM
Hello friends,
What would you suggest for a more durable finish for dinind table top.
I am not sure what is stronger, Arm R Seal or Waterlox Varnish ?
Thank you very much for your help!
Julian
-- Julian Paul Jones
15 replies so far
View TungOil's profile
TungOil
979 posts in 551 days
#1 posted 05-16-2017 06:03 PM
That’s a great question, and one that I’m just setting out to answer over the next couple of weeks myself, since I’m building a dining table right now.
I’m just preparing some test panels to try out these three finishes:
1) Waterlox Original Sealer/Finish
2) General Finishes Arm-R-Seal Oil & Urethane
3) Minwax Wipe On Poly
My sense is that the poly finishes will be more durable than the Waterlox, which I have used quite often and really like. From experience I know the Minwax is easier to apply and builds faster. I’ve not yet used the GF products, so I’m curious to see how the test panels look.
-- The optimist says "the glass is half full". The pessimist says "the glass is half empty". The engineer says "the glass is twice as big as it needs to be"
View Fax's profile
Fax
#2 posted 05-16-2017 06:16 PM
“TungOil” Thank you very much for your time and advice!
I really appreciate it!
Julian
View Rich's profile
Rich
3206 posts in 645 days
#3 posted 05-16-2017 06:25 PM
I can say from using it on a recent countertop that Waterlox Original, followed by Waterlox urethane is very durable. I mentioned it in another thread, but I panicked when I saw the tiler had stacked tiles on it, but it was unscathed. I’m very happy with the surface.
Arm-R-Seal gets rave reviews on here and people swear by it, so I’m sure it’s a great choice too.
View Fax's profile
Fax
#4 posted 05-16-2017 06:50 PM
Thank you Rich Taylor!
This is also good news for me because last year I refinished a customer’s dining table with Waterlox Original. I applied 3 coats of Original Waterlox. I didn’t use the Waterlox Urethane over it. I wonder if it is a big difference…I hope it is a strong finish.
View chrisstef's profile (online now)
chrisstef
17491 posts in 3062 days
#5 posted 05-16-2017 07:14 PM
I used arm-r-seal on some countertops I did a while back. I only lived with them for a year or so but they held up amazingly well. Make sure you get a couple coats on the bottom of the table as well so the table doesn’t take on moisture differently.
Id brush on 2-3 heavy coats and then wipe on another 3-4 or until I was happy.
View JADobson's profile
JADobson
1103 posts in 2167 days
#6 posted 05-16-2017 08:34 PM
If I remember right FWW did a test between a bunch of finishes and rated Arm-R-Seal as the easiest to apply and the most durable. Can’t remember if Waterlox was included in the test.
-- No craft is very far from the line beyond which is magic. -- Lord Dunsany — Instagram @grailwoodworks
View OSU55's profile
OSU55
1738 posts in 2045 days
#7 posted 05-16-2017 08:41 PM
If I remember right the FWW test rated MW poly pretty high. Dont buy the wipe on just thin the regular 1:1 with ms.
View Carloz's profile
Carloz
1147 posts in 647 days
#8 posted 05-16-2017 09:13 PM
Waterlox claims their product is the best thing after peanut butter with jelly. Strangely according to their comparison waterlox has no cons, just total pros over anything.
https://www.waterlox.com/Competitor-Comparisons
View Rich's profile
Rich
#9 posted 05-16-2017 09:25 PM
And your point is?
TungOil
#10 posted 05-16-2017 09:36 PM
July/Aug 2005 issue of FWW is the one you are thinking of, I just had it out. They rated the Minwax Wipe-on Poly as the top finish. Waterlox was tested also, as was Arm-R-Seal.
Water resistance rating, which is likely the most important thing they compared to the OP:
Minwax- excellent
Waterlox Original- good (High Gloss- excellent)
Arm-R-Seal- fair
View LittleShaver's profile
LittleShaver
339 posts in 675 days
#11 posted 05-17-2017 02:21 PM
When I built our dining room table a few year ago, I used MW gloss poly cut 50% with MS for the top coats. Seem to recall putting on 5-6 coats. Did all surfaces the same to minimize differential water absorption. Still looks like the day I finished it. The top was a single slab of white oak 36” wide, 96” long and about 2 1/2” thick.
-- Sawdust Maker
View pontic's profile
pontic
615 posts in 665 days
#12 posted 05-17-2017 07:47 PM
Kleer Kote #30 resin 39.86 per gallon covers 48sqft.
Crosslinked resin could tapdance on it.
-- Illigitimii non carburundum sum
5018 posts in 2549 days
#13 posted 05-17-2017 08:01 PM
Waterlox Original is a phenolic resin varnish, and extremely durable. That said, durable may not be the same a scratch resistant. That is the specialty of urethane formula varnishes, and is the only time I will use one (for scratch resistance). That’s why most of the floor formulas are urethane. I’d say either Arm-R-Seal or Waterlox would do exactly what you want. I left MW out because I personally consider them the Harbor Freight of the finish world.
View Carol's profile
Carol
59 posts in 569 days
#14 posted 05-17-2017 08:29 PM
used 3 coats of waterlox on my heart pine countertops. i’m very impressed with the amount of protection waterlox gives. the finish isn’t very scratch resistant tho, but i didn’t care much about scratches. what i like second best about waterlox is that to reapply, i don’t need to sand.
not a fan of general finishes; i find it yellows the wood. i’ve only used it on pine and red oak.
i’ll need to give the arm-r-seal a try.
-- Carol
View Rich's profile
Rich
#15 posted 05-17-2017 10:04 PM
I use a product from Mohawk on my Waterlox sealer/finish topped with Waterlox urethane called “Scratch & Mar Resister Polish.”
When I first sprayed it on, it appeared to bead up on the Waterlox and I figured I’d wasted my money. I used it on one side, rubbed it on with a microfiber cloth and then noticed a major difference in feel between the two sides. The polished side was much slicker, but without any sort of film or residue. It polished beautifully as well. I now use it regularly.
Its claim to fame is that it lubricates the surface, making it less likely that something will grab and dig in, leaving a scratch.
