IDEAS??
Forum topic by Gene Howe posted 11-17-2010 06:36 PM 705 views 0 times favorited 2 replies Add to Favorites Watch
View Gene Howe's profile
Gene Howe
10112 posts in 3332 days
11-17-2010 06:36 PM
I’m finishing up a SCMS bench. About 8’ long with a solid 3/4” plywood back. The back will be exposed and I want to hang a hinged shelf on it to hold a bench grinder, belt/disc sander and a 1” strip sander.
I’m leaning towards a HD continuous hinge with a folding set of supports.
Does anybody have any other suggestions?
Thanks folks.
2 replies so far
View shipwright's profile
shipwright
7894 posts in 2701 days
#1 posted 11-17-2010 07:09 PM
Sounds like you’ve got it pretty well scoped out Gene. If the folding supports are as I envision them you might put a stub dowel in the outer end of each facing up that indexes into a hole in the bottom of the shelf as a lock against “accidents”, but you probably already had that covered. .... I bet I know what the belt sander and strip sander look like too.
Gene Howe
#2 posted 11-17-2010 09:06 PM
Thanks Paul.
Nope. Not SS.
Old Deltas.
