Drill press technique question
Forum topic by leftcoaster posted 05-14-2017 05:35 PM 626 views 0 times favorited 5 replies Add to Favorites Watch
View leftcoaster's profile
leftcoaster
233 posts in 1116 days
05-14-2017 05:35 PM
Topic tags/keywords: drill press technique precision counterbore
I need to drill a 5/16” through hole with a 3/8” deep counterbore that is 3/4” in diameter.
What’s the best way to ensure that the 3/4” forstner bit is centered on the through hole after the bit change? Or should I drill the 3/4 first and then finish with the through hole?
5 replies so far
View HorizontalMike's profile
HorizontalMike
7770 posts in 3154 days
#1 posted 05-14-2017 05:42 PM
Using your 3/4in Forstner first will keep the 5/16in centered for the through hole.
View Woodknack's profile
Woodknack
12468 posts in 2620 days
#2 posted 05-14-2017 05:57 PM
+1 Mike, larger size first
HorizontalMike
#3 posted 05-14-2017 06:54 PM
And if you really wanted to be anal, go with 3/4in deep, 1/8in through, and then the 5/16in bit. This may help keep you from ripping out.
PLUS, don’t forget to use a “sacrifice” board underneath, as that also keeps the drill hole intact with NO tear-out.
View Madmark2's profile
Madmark2
409 posts in 828 days
#4 posted 05-14-2017 08:33 PM
Forstners will generally self-center as long as you start with the largest dia and work down.
M
leftcoaster
#5 posted 05-14-2017 08:55 PM
Thanks everyone – really appreciate the help!
