Most usefull Wooden Hand screw size?
Forum topic by eruby posted 11-16-2010 06:26 PM 8329 views 0 times favorited 12 replies Add to Favorites Watch
View eruby's profile
eruby
79 posts in 2676 days
11-16-2010 06:26 PM
Topic tags/keywords: clamp
I am in the market for a few wooden hand screws. I have seen sizes anywhere between 4” and 14” and would like to buy a couple that will actually get used. For example, I have learned that I hardly use F style clamps longer than 18” I have a couple but I prefer to use parallel clamps and pipe clamps for applications that call for longer reach.
I plan to use these things to extend my vice and allow me to clamp longer boards vertically to my bench and am sure I will discover plenty of other uses for them.
Which size hand screw clamps do you guys find you reach for most often and conversely which size is not that useful.
Thanks
Eric
-- Eric - Baltimore MD
12 replies so far
TopamaxSurvivor
18188 posts in 3577 days
#1 posted 11-16-2010 06:50 PM
Smaller ones for me. Regular clamps for bigger stuff.
View swirt's profile
swirt
2543 posts in 2873 days
#2 posted 11-16-2010 06:54 PM
Hard to say with any certainty without knowing what kind of things you plan on doing with them. That disclaimer aside, I have 8”, 10” and 12” handscrews and I use them all, but if I had to choose just one size I would go with the 10”. They are my happy medium.
View Dan's profile
Dan
3630 posts in 2782 days
#3 posted 11-16-2010 06:54 PM
I have a couple 10 inch hand screw clamps that I use quite often. I mostly use for clamping small pieces. I have never needed bigger then 10 inch.
-- Dan - "Collector of Hand Planes"
View jusfine's profile
jusfine
2422 posts in 2827 days
#4 posted 11-16-2010 07:44 PM
10 or 12” usually here as well, although a few 6” come in handy once in awhile.
-- Randy "You are judged as much by the questions you ask as the answers you give..."
View racerglen's profile
racerglen
3112 posts in 2682 days
#5 posted 11-16-2010 07:53 PM
I’ve got them from the smallest up to 10 inch, all in pairs and one 14 inch monster I found in a 2nd hand store from a high school woodshop..It’d been used at some point as a welding clamp !.. It’s basicly a show piece, used as a hanger for other clamps.
But most used are the 8” and 10 ” ones.
-- Glen, B.C. Canada
View RalphBarker's profile
RalphBarker
80 posts in 2671 days
#6 posted 11-16-2010 08:23 PM
The simple solution is to buy two of each size. A fella can’t have too many clamps, after all. ;-)
Once you catch on to the idea of using these in combination with other clamps, they become addictive.
eruby
#7 posted 11-16-2010 09:23 PM
Thanks for the input and I am surprised by the general consensus. I was expecting as many opinions as replys.
Sounds like the 10” clamps might be a good place to start. The buy “two of all of them” suggestion is tempting hmmm
View TheGravedigger's profile
TheGravedigger
963 posts in 3926 days
#8 posted 11-17-2010 01:49 AM
I mostly use 10’s & 12’s. I’ve got a few 6” ones, but they are a bit more of a specialty item. BTW, Harbor Freight often has good prices on them.
-- Robert - Visit my woodworking blog: http://littlegoodpieces.wordpress.com
eruby
#9 posted 11-17-2010 02:45 AM
Robert are the Harbor Freight hand screws one of the HF Gems? buying stuff there scares me.
If so I will have to keep an eye out for the sale
View Howie's profile
Howie
2656 posts in 2824 days
#10 posted 11-17-2010 05:15 AM
My handscrews are HF (2 of each size) and I would recommend them to anyone. Yep, made in China, look at where the ones from “other” vendors are made. Them and the corner clamps are some of HF “gems”
-- Life is good.
swirt
#11 posted 11-17-2010 05:38 AM
In my opinion Jorgensen or Dubuque Clamp Works handscrews are the most solid (both made in USA). My one harbor freight handscrew is better made than the ones sold by Rockler. The threads on the HF are better.
racerglen
#12 posted 11-17-2010 02:51 PM
If you’re into adaptations and build your own.. Lee Valley sells Jorensen kits, as below..:)
Somehow in my challenged fashon I got the text, but not the pictures ..oh well..
With these kits, it is easy to make your own handscrews.
The instructions include plans for making jaws exactly like those used on Jorgensen clamps, or you can custom-build jaws for round or irregular shapes, or extra-deep, long or thin jaws to suit other specialized applications.
Kit includes the same hardware that Jorgensen uses in its handscrews: Acme-threaded rods and barrel nuts for one handscrew clamp, plus instructions (but not wood).
Clamp sizes (maximum opening/jaw length) listed below.
Made in USA.
The 2”, 3”, 8-1/2”, 10” and 12” Kits are not stocked at our retail stores but can be ordered for pick-up.
1+ 4+
13F02.24 $9.20 $8.45
13F02.26 $10.80 $9.95
13F02.28 $12.10 $11.10
13F02.30 $13.80 $12.70
13F02.32 $17.80 $16.40
13F02.34 $18.20 $16.75
13F02.36 $22.40 $20.60
12” Kit (16” Jaw), each
