Sharpening Carbide
Forum topic by richardchaos posted 05-13-2017 02:21 AM 2454 views 0 times favorited 13 replies Add to Favorites Watch
View richardchaos's profile
richardchaos
583 posts in 462 days
05-13-2017 02:21 AM
Does anyone know of any way to SHARPEN Carbide tips Table/Chop Saw blades.
-- “In a time of universal deceit, telling the truth is a revolutionary act.” ― George Orwell
13 replies so far
View Loren's profile
10477 posts in 3730 days
#1 posted 05-13-2017 02:30 AM
You’re better off sending them out, imo but
sharpening equipment is available.
https://www.harborfreight.com/120-volt-circular-saw-blade-sharpener-96687.html
View papadan's profile
papadan
3584 posts in 3451 days
#2 posted 05-13-2017 02:35 AM
You can use a Dremel with cutting wheels. Use the sides of the wheels as a grinder.
View ArtMann's profile (online now)
ArtMann
1009 posts in 898 days
#3 posted 05-13-2017 02:35 AM
You need to buy a diamond hone. I use these from Highland Woodworking to touch up my good blades between sharpenings from a service. I also touch up router bits sometimes. There are many other choices for sale there and elsewhere.
View knotscott's profile
knotscott
8099 posts in 3458 days
#4 posted 05-13-2017 10:31 AM
I’d never attempt to sharpen a good blade myself, and lousy blades aren’t worth the effort. There is lots of potential to actually do more harm than good trying to sharpen yourself. If you’re careful you can hone the faces yourself. Otherwise, just keep them clean, and when the time comes, have them professionally sharpened for ~ $15.
View Woodbum's profile
Woodbum
819 posts in 3148 days
#5 posted 05-13-2017 11:29 AM
Send them to a pro sharpening service. In general, their pricing is cheap enough not to risk doing more harm than good on an expensive carbide blade. Kind of like trying to save a few bucks by removing your own appendix with a butter knife, using a six pack of Pabst for the anesthetic.
-- "Now I'm just another old guy wearing funny clothes"
richardchaos
#6 posted 05-13-2017 12:56 PM
Already there. watched a video on youtube last night
- ArtMann
richardchaos
#7 posted 05-13-2017 12:57 PM
PABST! UGH!
- Woodbum
View Planeman40's profile
Planeman40
1201 posts in 2843 days
#8 posted 05-13-2017 01:07 PM
Carbide can only be sharpened with diamonds. I agree that using a sharpening service is best, but if you must, do it with diamond sharpening disks and cups. Fortunately, these days these are not too exorbitant, but not cheap. Google that term and see what you find. Most of these are made in China so look to buying them direct from China. Google “buy direct from China” and you will find sites like Banggood and AliExpress. Also, you can sharpen by hand using a Dremel tool with diamond disks like these from Harbor Freight https://www.harborfreight.com/diamond-rotary-cutting-discs-5-pc-69657.html.
I sharpen my drills and router cutters using these disks.
View TheFridge's profile
TheFridge
9856 posts in 1568 days
#9 posted 05-13-2017 01:51 PM
What’s wrong with Pabst…
I sharpened a 60t blade myself with a dremel diamond disc. It was an improvement. I setup a jig and everything. Then I found out carbide dust is horrible for you. Made me sick for a couple days. Since then I decided to pay 20$ and send it out.
runswithscissors
2804 posts in 2107 days
#10 posted 05-15-2017 05:21 AM
The green grinding wheels work on carbide. I don’t know what the material is, but it does grind carbide. Somewhat more expensive than an ordinary aluminum oxide wheel, but not a lot more.
View BigYin's profile
BigYin
421 posts in 2499 days
#11 posted 05-15-2017 08:57 AM
is all about money.
If you have a cheap blade its disposable, all second hand wood goes through cheap blades if i hit a nail i dont cry.
If you have a good blade it goes to the saw doctor to be sharpened on a CNC diamond grind saw sharpener. Good blades have finer grain carbide, take and hold a sharper edge and generally cut better.
-- ... Never Apologise For Being Right ...
View OldCoach's profile
OldCoach
47 posts in 957 days
#12 posted 05-16-2017 04:26 AM
I use a diamond blade used for cutting tile on a cheap 10” portable saw that I keep around just for this task. Just touch the carbide tip to the diamond blade with just enough pressure to hold it for a second or two. Of course all my blades are less expensive box store blades. If I used high dollar blades I might use a professional.
-- Play cowboy on weekends and make sawdust in between when not watching football
View DirtyMike's profile
DirtyMike
637 posts in 984 days
#13 posted 05-16-2017 04:50 AM
a cheap wet saw with a diamond blade and a jig to help match the angles will work. results will be okay but not good.
