small shelf support needed
Forum topic by AaronK posted 11-16-2010 01:28 AM 1185 views 0 times favorited 7 replies Add to Favorites Watch
View AaronK's profile
AaronK
1506 posts in 3461 days
11-16-2010 01:28 AM
I’m building something like this shelf. Instead of drilling through holes to screw the shelf to the wall at top and bottom, I was hoping for a sort of hardware keyhole I could set into mortises in the back and so make the supports invisible. searching the net turned up nothing, but I’m sure i’ve seen this sort of thing before – can someone point me in the right direction?
7 replies so far
View Mary Anne's profile
Mary Anne
1058 posts in 3205 days
#1 posted 11-16-2010 01:39 AM
Why not use a router with a keyhole bit and skip the mortise?
View woodcrafter47's profile
woodcrafter47
352 posts in 3102 days
#2 posted 11-16-2010 01:47 AM
Yep, my thought as well.keyholebit. Used them and they work well .
-- In His service ,Richard
View Tomoose's profile
Tomoose
422 posts in 3370 days
#3 posted 11-16-2010 02:33 AM
These fasteners at Woodcraft came to mind by what you described. I have used similar pieces to hang small shelves. http://www.woodcraft.com/Product/2001928/1891/Single-Hole.aspx
Tom
-- “I am always doing that which I cannot do, in order that I may learn how to do it.” Pablo Picasso
View SnowyRiver's profile
SnowyRiver
51457 posts in 3477 days
#4 posted 11-16-2010 03:19 AM
Yep, I agree with Mary Anne, a router keyhole bit works great and no hardware is required.
-- Wayne - Plymouth MN
View plantek's profile
plantek
312 posts in 2796 days
#5 posted 11-16-2010 04:18 AM
You can buy the metal keyhole hangers at Lowe’s.
But I have to agree with prior posts that a keyhole bit works great.
-- If you want it and it's within reason... It's on it's way!
AaronK
#6 posted 11-16-2010 06:11 AM
thanks! that little piece is it exactly! I’d do the keyhole bit way except i need this done fast and im running out of time :-) thanks all!
woodcrafter47
#7 posted 11-16-2010 04:21 PM
Practice on scrap piece first. it can get tricky.
