Sanding sealer on Plywood
Forum topic by dmoe posted 05-12-2017 03:17 PM 335 views 0 times favorited 0 replies Add to Favorites Watch
View dmoe's profile
1 post in 314 days
05-12-2017 03:17 PM
I am working on some pieces of art work that I have burned electronically in 1/2 plywood using a Lichtenburg / fractal burning transformer. I would like to inlay colored epoxy resin into the burn patterns… the problem I am running into is the resin is soaking into the surface of the plywood and as I sand it to remove the excess (not in the cracks) I am sanding through the top layer of the plywood… I am trying CA glue with turquoise inlay and having the same issue. Would applying a sanding sealer, finish wax, (or other product???) to the surface of the plywood fill the pores and not allow the epoxy and/or glue to soak through the top layer, thus, making it easier to sand the excess away?
Anyone have experience with this or something similar?
0 replies so far
