My first coffee table
Forum topic by christherookie posted 05-12-2017 01:54 PM 472 views 0 times favorited 5 replies Add to Favorites Watch
View christherookie's profile (online now)
christherookie
77 posts in 3163 days
05-12-2017 01:54 PM
Topic tags/keywords: finish stain shellac varnish
With a handful of projects under my belt, I’m ready to make a coffee table. What I don’t know is how it should be finished. I know it will get its share of cups, mugs, and plates resting on the surface. I just don’t know shellac from shinoal about what to use to protect it. if I stain it, what do I use to cover the stain? Do I use shellac? Again, I’m new at this.
5 replies so far
View ChefHDAN's profile
ChefHDAN
1122 posts in 2966 days
#1 posted 05-12-2017 03:05 PM
If you’ve got kids I strongly recommend water based polyurethane, it’s easy to apply easy to clean up, and i have proven with three kids through their teenage years that it will endure.
View pintodeluxe's profile
pintodeluxe
5739 posts in 2930 days
#2 posted 05-12-2017 03:13 PM
Sprayed lacquer is my favorite. Two coats and you’re done.
Many people also rave about general finishes wipe-on Arm-R-Seal, which is a urethane.
It may take a little more time to build a finish, but if you don’t have spray equipment it may be the best choice.
As with any new finishing schedule, make sample boards and finish them with each step you plan to use (including sanding through different grits).
View OSU55's profile
OSU55
1833 posts in 2106 days
#3 posted 05-12-2017 03:14 PM
If you want to add color, subtle to intense, dyes are the best. Since you are new at this, look at general finishes dye stains. Eventually you will want to mix your own (easy to do). For a topcoat, water borne (gf has one) or oil based poly (minwax works great for me). If wiping or brushing, recommend oil based. Yes ob poly can go on over wb dye/stain, and vice versa, but wipe ob stain with dna/h20 1:1 before applying wb finish.
View Rich's profile
Rich
3527 posts in 706 days
#4 posted 05-12-2017 03:34 PM
Shellac, lacquer, poly — both oil and water borne — are all good choices for a coffee table. I’d recommend taking some scrap, sand it like the table will be, and play around with all of them. See which one you get the best results with.
Edit: reading Willie’s post, which came along while I was getting around to my reply, reminded me that wiping is so much easier than brushing if you don’t have a sprayer. In fact, Minwax wipe-on poly is about as foolproof as you can get, but there are lots of other options like he mentioned.
View Ub1chris's profile
Ub1chris
123 posts in 1497 days
#5 posted 05-12-2017 03:39 PM
I like wipe on poly for something like this. It’s hard to mess up. Goes in easy and quick and provides good protection. Better with more coats.
