Lifting help needed
Forum topic by rolltopbox posted 11-15-2010 07:34 PM 1701 views 0 times favorited 16 replies Add to Favorites Watch
View rolltopbox's profile
rolltopbox
71 posts in 2991 days
11-15-2010 07:34 PM
Topic tags/keywords: material handling lifting assist lifting heavy
Never mind, I found something.
Bruce
-- Bruce http://www.finecraftfurniture.com
16 replies so far
View mtnwild's profile
mtnwild
3474 posts in 3524 days
#1 posted 11-15-2010 08:23 PM
Pretty vague question.
You could try and slowly lift each end and brace, until you build a lift all the way to the bench top.
Good luck…..........
View grizzman's profile
grizzman
7836 posts in 3300 days
#2 posted 11-15-2010 08:38 PM
you need a block and tackle…or a come along winch…i have a block and tackle that hangs from my shop rafters…and is there for any type of heavy lifting…i leave it there for the times when needed…they are great…or buy a cheaper come along….do the same …hang it from your rafters or if you have a closed ceiling.you will need to figure out a way to hang it…thats my 2 cents….
-- GRIZZMAN ...[''''']
View hairy's profile
hairy
2701 posts in 3529 days
#3 posted 11-15-2010 09:01 PM
Warning! This is harbor freight!
http://www.harborfreight.com/1000-lb-capacity-hydraulic-scissor-table-cart-93116.html
I have read good reviews on other ww’ing sites, but I have no experience with it.
They also have a lower priced version.
-- My reality check bounced...
TopamaxSurvivor
18269 posts in 3673 days
#4 posted 11-15-2010 09:35 PM
Pry up a corner, put a block under it, keep moving around and prying with blocks until it is as high as you want it. Be sure you use wide enough blocks to maintain satbility.
View GMman's profile
GMman
3902 posts in 3694 days
#5 posted 11-15-2010 09:56 PM
Get two stong guys
TopamaxSurvivor
#6 posted 11-15-2010 10:38 PM
Better make it 4 Gmman ;-))
View Dennisgrosen's profile
Dennisgrosen
10880 posts in 3112 days
#7 posted 11-15-2010 11:01 PM
take a manuelpalletlmover and make two long wedges you can pull it up on to another pallet with a mdfboard on
then reliafe the handle and the thing on the pallet will now bee at a high of four inches ungefair
take care
Dennis
View canadianchips's profile
canadianchips
2600 posts in 2994 days
#8 posted 11-15-2010 11:17 PM
My parents called Me, If its 100 lbs, I use one hand, up to 500 lbs, two hands, Over 500 lbs, they called my brother to help me. lol
AND now I wonder why I have 2 dics missing in my lower back ! REALLY
If you have strong enough rafters, I suggest a block and tackle from ceiling. A couple of pulleys makes quite the difference. Make certain your rafters are STRONG enough !
mtnwild
#9 posted 11-15-2010 11:43 PM
Hey Bob, that’s what I was trying to say, ;}
500 pounds is too much to try and hand lift. Too much chance for injury or damage.
GMman
#10 posted 11-16-2010 05:15 AM
Remember how they use to change a car motor in the old days a tri pod with a chain block, way to go.
Hey Bob 200lbs in my younger days was light for me.
View cutmantom's profile
cutmantom
405 posts in 3032 days
#11 posted 11-16-2010 05:23 AM
scissor lift table
View djwong's profile
djwong
176 posts in 3217 days
#12 posted 11-16-2010 06:03 AM
I have no choice but to make room for an engine lift in my shop/garage. My engine lift at least has foldable legs to reduce it’s footprint. If I get really disparate for space, I can disassemble the engine lift to store it even more compactly. If I had room, I would have installed an overhead beam and used a hoist assembly.
-- David W. Cupertino, CA
TopamaxSurvivor
#13 posted 11-16-2010 06:33 AM
GMman, what’d ya have in your other hand? 6 pack :-))
View BobG's profile
BobG
172 posts in 2959 days
#14 posted 11-16-2010 01:28 PM
Hire two-men -and-a-truck!
Seriously the safest way would be to use an engine block lift. They usually have wheels and can lift about 4 feet off the floor. But, then again I’m not sure I’d even consider moving something that heavy without some strong men and plenty of beer! At least you would have a lot of company while you waited for the guys in the truck!
On second thought a swing arm crane mounted somewhere on your wall wound work!
100 LBS not a problem call me buy my dinner and I’ll do it!
200 LBS call me (see above) and pay for gas!
300 LBS or above call me I probably won’t answer the phone!!
What weighs 500 pounds in a wood shop??
-- BobG, Lowell, Arkansas--------My goal in life is to be the kind of person my dog thinks I am! Make more saw dust!!
View jcwalleye's profile
jcwalleye
306 posts in 3070 days
#15 posted 11-17-2010 04:48 AM
Here’s a link to a review on the HF 500 lb lift. This table gets more useful all the time. The only thingI’d add is the hydraulics loses a little pressure over time. But it’s so easy to raise, it’s a non issue for me.
-- Trees, a wonderful gift --Joe--
