How flat is flat enough?
« back to Hand Tools forum
Forum topic by dakremer posted 05-11-2017 04:45 PM 970 views 0 times favorited 14 replies Add to Favorites Watch
View dakremer's profile
dakremer
2742 posts in 3331 days
05-11-2017 04:45 PM
Topic tags/keywords: hand plane refurbish fix flatten
I’m practicing refurbishing a cheaper Stanley Hand Plane, in hopes of gaining some experience before finding a good one to refurbish. I got a 3/8” thick piece of glass and am flattening the bottom of the plane.
I started with 120 then 220, and then finished with a few passes of 500.
You can see there’s a dip in the center of the sole, and its also not completely flat around the mouth. (thats a shadow at the heel end of the sole) Is this good enough? Or do I need to continue flattening? Thanks!
-- Hey you dang woodchucks, quit chucking my wood!!!!
14 replies so far
View chrisstef's profile
chrisstef
17800 posts in 3245 days
#1 posted 05-11-2017 04:50 PM
Imo, youre good. Front of the mouth and the heel seem to be even and thats about all that matters.
dakremer
#2 posted 05-11-2017 04:51 PM
- chrisstef
It’s completely flat except for that little dip in the center, and its not completely flat directly around the mouth
View JayT's profile
JayT
6009 posts in 2450 days
#3 posted 05-11-2017 04:52 PM
If the toe, heel and front of the mouth are co-planar, you are good, so depends on where your “not completely flat around the mouth” is at and how bad. A bit of a hollow where that is at is never going to be a problem.
My first few planes, I flattened and spent way too much time trying to get just perfect. Now, I sharpen it up, do a basic tuning, then use it and see what happens. If it works well, I don’t even bother checking how flat. If it doesn’t perform to my standard, then it’s time to see what else needs done. So regardless of what else is said, the big question is – How does it perform?
-- In theory, there is no difference between theory and practice. In practice, there is.
dakremer
#4 posted 05-11-2017 04:54 PM
I’ll let you know how it performs shortly! Going to finish sharpening the blade real quick and give it a test drive! I’ll get back to you in 10 minutes :)
View RustyHacksaw's profile
RustyHacksaw
145 posts in 1503 days
#5 posted 05-11-2017 05:01 PM
My prediction is that plane will pull a fine shaving.
dakremer
#6 posted 05-11-2017 05:24 PM
Being the first time I’ve ever used a flat/sharp plane, I’d say this is pretty damn good. Of course I have nothing to compare it to. Excited to try a really good plane/blade
View Jim Jakosh's profile
Jim Jakosh
21967 posts in 3345 days
#7 posted 05-11-2017 05:31 PM
Looks good to me!!
Jim
View Bill White's profile
Bill White
5149 posts in 4199 days
#8 posted 05-11-2017 05:38 PM
I think that you are DONE. Good work. Now, get busy makin’ more shavings. :)
Bill
-- bill@magraphics.us
View Roger's profile
Roger
20965 posts in 3043 days
#9 posted 05-14-2017 12:20 PM
I’m not a plane guy, but, I’d say you’re doing a fantastic job. That ribbon is proof, that baby is sharp. Carry on.
View splintergroup's profile
splintergroup
2511 posts in 1461 days
#10 posted 05-14-2017 01:55 PM
Results look excellent!
You know you are “perfect” when you can take cuts that produce shavings with only one side.
View waho6o9's profile
waho6o9
8539 posts in 2816 days
#11 posted 05-14-2017 02:06 PM
Good job Doc.
A little Gulf wax on the sole and you’ll be making curlies all day:
View OSU55's profile
OSU55
2033 posts in 2229 days
#12 posted 05-14-2017 04:17 PM
View Andre's profile
Andre
2367 posts in 2045 days
#13 posted 05-14-2017 04:34 PM
As a side note, I always square at least one side of the body (right or left handed?) while flatten my planes in case you want to use it for shooting of your bench or on a board. I use self adhesive sand paper from auto body supplier I the 180 to 220 grit range stuck to a cast jointer or table saw top.
View Smitty_Cabinetshop's profile (online now)
Smitty_Cabinetshop
15820 posts in 2857 days
#14 posted 05-15-2017 12:20 PM
Nice progress, Dak. When the time comes that you’re able to hit finished work with your smoother, hear the sound and feel the soft surface left behind, planes will be part of your shop arsenal for the long haul.
