Adhesive Advice!
« back to Joinery forum
Forum topic by Jacksmith24 posted 05-11-2017 02:15 PM 613 views 0 times favorited 4 replies Add to Favorites Watch
View Jacksmith24's profile
Jacksmith24
3 posts in 556 days
05-11-2017 02:15 PM
Topic tags/keywords: padauk
Good morning!
I know a bit about adhesives, but I have a project that I need advice on. I am actually making a a pendant for a necklace, a butterfly. It will be a three layer laminate, Padauk for the middle layer, with Ebony for the front and back. Typically I would use something like Titebond III and clamp it, but the catch is that the front and back will be fretwork cut out so that the Padauk shows through. So wood glue is out because it will mess up the effect or clog the holes. So I’m wondering…if I layer polyurethane on the pieces, then clamp them together, will the poly act as a sort of clear adhesive? It is only a charm for a necklace, so it doesn’t have to be overly strong, I just need a clear, thin adhesive that won’t hide the wood’s color or figure.
Thanks!
Jack
View pontic's profile
pontic
634 posts in 784 days
#1 posted 05-11-2017 02:20 PM
I’ve done this before. It does work, but you need to use a fast drying oil based type. Cyanoacrylates work well too.
-- Illigitimii non carburundum sum
View hairy's profile
hairy
2780 posts in 3708 days
#2 posted 05-11-2017 02:27 PM
Good info here
http://www.thistothat.com/
-- My reality check bounced...
Jacksmith24
3 posts in 556 days
#3 posted 05-11-2017 02:47 PM
Thanks! I planned to use either a brush on oil based poly or the wipe on oil based, both Minwax, I believe.
I considered cyanoacrylate, but was concerned that anything that squeezes out will react with top coats of polyurethane or might be a noticable color difference.
Jack
xx
I ve done this before. It does work, but you need to use a fast drying oil based type. Cyanoacrylates work well too.
- pontic
- pontic
Jacksmith24
3 posts in 556 days
#4 posted 05-11-2017 02:48 PM
Thanks! It didn’t really help in this situation, but I have always wondered if there was a site like that.
Good info here
- hairy
