Need suggestions on a TS zero clearance insert
Forum topic by WoodenSoldier posted 11-15-2010 06:13 AM 2025 views 1 time favorited 9 replies Add to Favorites Watch
View WoodenSoldier's profile
WoodenSoldier
161 posts in 3147 days
11-15-2010 06:13 AM
Topic tags/keywords: tablesaw zero clearance insert hitachi
Hoping I can gain a little advice from the vast experience of some of the folks here:
I’d like to put a zero clearance insert into my Hitachi table saw but it doesn’t seem very well designed for it. The current insert is metal and very thin. If I were to make I new one, I can’t see anything to mount it to. The recessed lip that the current one sits on is maybe a 1/4 inch (probably less).
I thought maybe I could mount something to the blade shroud? Has anybody had any similar experiences.
In the pictures, the current insert is the red rectangle to the right.
IMG_8758
IMG_8759
Thanks for any help!
-- Create something everyday.
9 replies so far
View JAGWAH's profile
JAGWAH
929 posts in 3286 days
#1 posted 11-15-2010 06:18 AM
You might consider the metal thickness and see if 1 or 2 layers of formica glued together can be used. Drill the holes, mount , move your fence over the insert so it doesn’t move up and slowly raise what blade you use into the material. Viola! Insert.
i’ve done similar for an old Makita I used to have.
-- ~Just A Guy With A Hammer~
View JimDaddyO's profile
JimDaddyO
578 posts in 3281 days
#2 posted 11-15-2010 03:36 PM
I have a similar situation and made mine from 2 pieces. The top is lexan or polycarbonite and the same thickness as the orignal metal part. Then I made the bottom part that goes into the hole from ply and contact cemented them together.
-- my blog: http://watertoneworkshop.blogspot.ca/ my You Tube channel: https://www.youtube.com/channel/UCA5AretE3xPoVDV61AxUdUA?view_as=subscriber
View Roger's profile
Roger
20952 posts in 3006 days
#3 posted 11-15-2010 04:19 PM
Yup. What Jagwah said….. If a 10” blade is too tall when you try n raise it up through your new insert, you could use a smaller diameter blade. Either use your fence to keep it down when raising the blade up (slowly), or just clamp a scap piece of 2×4 or anything across the table to hold the insert down while the blade is coming up through.
View Radu's profile
Radu
330 posts in 3246 days
#4 posted 11-15-2010 04:45 PM
Just watch the blade flange while you raise the blade up. (don’t ask me how I know it). I built mine out of two pieces (look under my projects)
View Cato's profile
Cato
701 posts in 3515 days
#5 posted 11-15-2010 04:49 PM
Maybe some 1/4 inch hardboard would work, otherwise wise you may have to plane down to thickness of your OEM.
View Jim Finn's profile
Jim Finn
2687 posts in 3124 days
#6 posted 11-16-2010 04:03 PM
” rout out the bottom side where the lips are to allow it to sit flush.” <<<<<< Good advice! When raising the running blade up though the new insert place the fence near the blade to hold the inseret down while cutting it from below.
-- No PHD just a DD214 Website> craftingcouple.com
View FreddyS's profile
FreddyS
211 posts in 2976 days
#7 posted 11-16-2010 07:17 PM
Hi, I just made a zci for my cheapo ryobi TS routing out lips etc. on the back of the plate and tested until it fitted correctly.
Btw. I used 1/2” plywood and the left side of the plate ended up being too thin so the blade took off small chunks of the bottom layer on the ply (cheapo ply maybe?), I just looked around for the pieces I could find and glued them back in place, also gave the thin side a coat of glue and it made it stiffer.
In your TS it looks like left side spacing is really thin, if going with routing, you may want to use 3/4” or 1/2” x 2 glued up together for extra support, looks like there’s enough space below.
-- Learning one thing at a time
View spunwood's profile
spunwood
1202 posts in 3038 days
#8 posted 11-16-2010 07:30 PM
I believe if you call leecraft they may have one built for your table saw just recently.
-- I came, I was conquered, I was born again. ἵνα ὦσιν ἓν
WoodenSoldier
#9 posted 11-23-2010 07:19 AM
Thanks for all the great advice!
