Raised panel router bits in shaper
« back to Joinery forum
Forum topic by TechTeacher04 posted 05-10-2017 11:43 PM 479 views 0 times favorited 2 replies Add to Favorites Watch
View TechTeacher04's profile
TechTeacher04
364 posts in 1435 days
05-10-2017 11:43 PM
Topic tags/keywords: question router
I apologize if this has been posted before, has anyone cut raised panels using 1/2” router style raised panel bits with a shaper and router but adapter. Based on speed recommendations I should be fine, I am curious what others have tried and how their results are. I have a G1035 1-1/2hp shaper in my home shop for personal hobby type use. I have both the 1/2 and 3/4” spindles and the 1/4&1/2” adapter. Will a freud router type bit work or should I just order shaper cutters? I appreciate an insights or advice, thank you
2 replies so far
View cabmaker's profile
cabmaker
1694 posts in 2713 days
#1 posted 05-11-2017 01:00 AM
it would would work if you have the interchangeable collet spindle.
changing it out is simple, but installing a proper cutter is much simpler
buy the raised panel cutter,,,,,,you ll be happier
runswithscissors
2652 posts in 1929 days
#2 posted 05-11-2017 08:20 PM
I use router bits in my shaper with no problem. Works well.
