How do I cut full blind splined mitres?
« back to Joinery forum
Forum topic by rolandstronghammer posted 05-09-2017 04:39 PM 1789 views 0 times favorited 21 replies Add to Favorites Watch
View rolandstronghammer's profile
rolandstronghammer
49 posts in 917 days
05-09-2017 04:39 PM
The title says it all. I dont have a Festool Domino so im not sure how to do this otherwise and accurately. It needs to be precise so that the mitre edge is clean.
Something like this
The only thing I can find is this jig which is something that could be manipulated so that the router bit cuts into the center of the miter. Then I can clean up the edges with a chisel and install the spline.
21 replies so far
View Picklehead's profile
Picklehead
1041 posts in 1984 days
#1 posted 05-09-2017 04:50 PM
Biscuit joiner.
-- You've got to be smarter than the tree.
rolandstronghammer
#2 posted 05-09-2017 04:56 PM
Biscuit joiner.
- Picklehead
I’d prefer a spline because biscuits are a bit weak for the application. Not to mention a biscuit joiner is $100.
View bandit571's profile
bandit571
20473 posts in 2738 days
#3 posted 05-09-2017 05:39 PM
Hammer and chisel..
Closed up to make this..
Top and bottom of the joint look like a simple miter joint…
Full Blind mitered Finger Joints…
rolandstronghammer
#4 posted 05-09-2017 05:46 PM
- bandit571
That would be perfect but i don’t have the skills to do something like that at this point. Also, the miter has to be perfect and i think in order for this to come out clean you need to have done it plenty of times. Perhaps this is easier than it looks because it looks quite hard.
View johnstoneb's profile
johnstoneb
2971 posts in 2228 days
#5 posted 05-09-2017 05:53 PM
I understand you don’t have a biscuit joiner but biscuits in this application would be just as strong as a spline. a router would probably do what you want, Can you use dowels?
-- Bruce, Boise, ID
rolandstronghammer
#6 posted 05-09-2017 05:54 PM
I understand you don t have a biscuit joiner but biscuits in this application would be just as strong as a spline. a router would probably do what you want, Can you use dowels?
- johnstoneb
Yes dowels would work but how do I drill them at a 45 degree angle.
View builtinbkyn's profile
builtinbkyn
2525 posts in 995 days
#7 posted 05-09-2017 05:56 PM
You can make that cut on your table saw. However it obviously needs to pass thru the top and bottom edges of the boards, which will expose the miter. I guess it would be possible to use the same species for the spline and that would somewhat camouflage the spline. The alternative would be to band the top and bottom edges with the same species, to conceal the spline.
-- Bill, Yo!......in Brooklyn & Steel City :)
rolandstronghammer
#8 posted 05-09-2017 05:57 PM
- builtinbkyn
I’d like it to be hidden. This would definitely work but i really do want it fully blind.
bandit571
#9 posted 05-09-2017 06:06 PM
That WAS the first time I tried that joint.
I did post a blog about it, BTW. “Hidden Finger Joints” I think was the title…
Really not that hard to do, depends on how well you can handle a small saw, a chisel or two, and do a layout.
View jbay's profile
jbay
2430 posts in 954 days
#10 posted 05-09-2017 06:10 PM
I didn’t see how wide your piece is?
You could clamp the piece to your table saw fence and raise the blade, making sure the piece is centered so that you don’t come out the front or back. Move the fence and do it a second time if you want a fatter cut.
Then make 1 big football/sawblade shaped spline to fill it.
*NOTE: My saw doesn’t come straight up.
You would have to raise the blade to the height you want, and then make your marks where to put the piece on your fence.
View duckmilk's profile
duckmilk
2969 posts in 1379 days
#11 posted 05-09-2017 06:12 PM
- builtinbkyn
This would work. Mill the pieces slightly wider than needed, rip a thin veneer off of each edge, cut the slot on the table saw, glue the cut off veneer pieces back on. Should be virtually invisible.
-- "Duck and Bob would be out doin some farming with funny hats on." chrisstef
bandit571
#12 posted 05-09-2017 06:13 PM
Router table?
Cut your miters first. Install a bit the correct size for the spline. Establish a start and stop point on the fence, set the fence to where the slot is centered in the end of the board. Cut will be a plunge cut. Plunge down at the start point, slide over to the stop point.
You might rig up a sled to hold the piece at the 45 degrees needed, and have it so you can slide the part onto the bit to start the cut. When you reach the end of the cut, you can slide the piece either back a bit, or shut off the router, and remove the finished piece.
rolandstronghammer
#13 posted 05-09-2017 06:19 PM
I didn t see how wide your piece is?
You could clamp the piece to your table saw fence and raise the blade, making sure the piece is centered so that you don t come out the front or back. Move the fence and do it a second time if you want a fatter cut.
*NOTE: My saw doesn t come straight up.
- jbay
Its roughly 2ft wide so this would work. not sure how to control the height of the blade so that the depth is consistent on both cuts.
rolandstronghammer
#14 posted 05-09-2017 06:23 PM
Router table?
- bandit571
That’s what i was thinking except the pieces are too large to be held up at a 45 degree angle. I think i’d need to hold the router at a 45 degree angle and use a template and a straight bit to cut the spline slot.
builtinbkyn
#15 posted 05-09-2017 07:02 PM
If the pieces are that wide, you can make the cut on your TS with stops. Then you have two choices as I see it – 1. make a spline and then taper the ends to match the blade cut. 2. clean out the rest of the cut with a chisel. Obviously you’ll need to test this all on scrap :)
