Deck screws how many per board per joist
Forum topic by MHW posted 05-09-2017 04:33 PM 3384 views 0 times favorited 10 replies Add to Favorites Watch
View MHW's profile
8 posts in 342 days
05-09-2017 04:33 PM
Topic tags/keywords: deck screws
Do I really need 2 screws per joist on my deck boards rather than doing 2 screws for one joist and then one on the next joist? 10 ft p/t boards on 16” joists.
10 replies so far
View crank49's profile
4030 posts in 2905 days
#1 posted 05-09-2017 04:52 PM
Two screws to prevent cupping of deck boards.
View dday's profile
142 posts in 1364 days
#2 posted 05-09-2017 05:07 PM
- crank49
View JCamp's profile
540 posts in 485 days
#3 posted 05-09-2017 05:13 PM
2 is fine as long as its a 6inch wide board. I have, and have known ppl, that swear by using 3 screws in a 6in wide board. Slightly over kill but they will not move
-- Whatsoever thy hand findeth to do, do it with all thy might
View johnstoneb's profile
2819 posts in 2107 days
#4 posted 05-09-2017 05:55 PM
You don’t say how wide. 4” 1 screw alternating side would work. 6” you need 2 per joist.
-- Bruce, Boise, ID
View LiveEdge's profile
574 posts in 1555 days
#5 posted 05-09-2017 06:05 PM
If you are going to go through the work of doing your own deck, pay the extra $10 in screws and do the extra time to put the additional screws in. It’s not the place to try to cut corners.
View DrDirt's profile
4421 posts in 3677 days
#6 posted 05-09-2017 07:06 PM
Depends – There are also hidden fastners which is what I did with my decking… where there is a biscuit made out of plastic with a built in spacer, so that you would hold the board by its edges
Then I use two screws per board on the joist at each end.
For direct screw down… the screws hold the board in place, and prevent cupping, thus 2 is standard.
View OldCoach's profile
47 posts in 809 days
#7 posted 05-10-2017 02:11 AM
Not to change the subject, but I built a deck 16 years ago using deck screws, the green ones. Never have I been so disappointed in a product. I cannot tell you how many screws failed due to rust and decay. I used two per joist on 6” wide boards by the way.
Last fall I removed this deck and replaced it with concrete. I would estimate that 90% of these deck screws were decayed to the point where they were no longer doing the job they were designed for. Plus the fact that now I have all this deck wood that I have to spend so much time just trying to get pieces of screws out in order to reuse for planter boxes or any other projects I want to use it for. I used 35 pounds of screws to build this deck. After demo, I have less than 5 lbs of screws that are not decayed that I can reuse on these other projects.
If I had to do it all over, I would use nails. Just my experience.
-- Play cowboy on weekends and make sawdust in between when not watching football
View Matt Hegedus's profile
Matt Hegedus
146 posts in 728 days
#8 posted 05-10-2017 04:19 AM
Built about 20 decks start to finish with a crew, and we always used 2 screws on wood decks, (torx head outdoor screws, predrilled with an 1/8” pilot hole) UNLESS we were using composite decking boards with hidden fasteners. Hidden fasteners required 1 screw per joist, but these boards were not prone to cupping.
-- From Pittsburgh, PA
View rwe2156's profile
2844 posts in 1415 days
#9 posted 05-10-2017 01:45 PM
Countersink/predrilling make for a professional job. This is especially critical on butt ends.
And don’t over screw the screws even counter sinking this can result in splitting.
I think sanding and using a stain/sealer really makes it a good job, even with PT wood.
I’ve built quite a few decks and I really think 12D stainless steel ring shank nails are worth considering.
View ArtMann's profile
902 posts in 751 days
#10 posted 05-10-2017 04:33 PM
All I want to say is that I have built several decks and I agree 100% with rwe2156. Ring shank nails are great but I would shoot them with a pneumatic nail gun. I am too lazy to hammer them in.
