Hardening Oil
Forum topic by dustbunny posted 11-14-2010 01:32 PM 4053 views 0 times favorited 8 replies Add to Favorites Watch
View dustbunny's profile
dustbunny
1149 posts in 3203 days
11-14-2010 01:32 PM
I built a US Postal mail truck bank with the plans from Rockler as a Christmas gift for my grandson.
The plans call for a hardening oil finish to be wiped on.
What would you recommend as a good hardening oil to use ?
I would prefer that the finish has a satin like look to it.
Thanks for any ideas you have to recommend,
Lisa
-- Imagination rules the world. ~ Napoleon Bonaparte ~ http://quiltedwood.com
8 replies so far
View grizzman's profile
grizzman
7836 posts in 3211 days
#1 posted 11-14-2010 03:57 PM
i love using tung oil on a lot of projects…..several coats would give a nice finish to your gift for your grandson..but ,maybe others will suggest something better…just my 2 cents…grizz
-- GRIZZMAN ...[''''']
View Gene Howe's profile (online now)
Gene Howe
10137 posts in 3336 days
#2 posted 11-14-2010 04:05 PM
Watco is easy.
Don’t get it on the brass door, whatever you use.
View Jamie Speirs's profile
Jamie Speirs
4167 posts in 2764 days
#3 posted 11-14-2010 04:09 PM
I’m a Danish Oil fan.
It has a hardener in it already.
I think the hardener they use is JAP..
Jamie
-- Who is the happiest of men? He who values the merits of others, and in their pleasure takes joy, even as though 'twere his own. --Johann Wolfgang von Goethe
35100 posts in 4308 days
#4 posted 11-14-2010 04:41 PM
I make my own 1/3 Varnish, 1/3 BLO, 1/3 Mineral Spirits and a 1/2 a cap of Japan Drier It will harden in the container so use all you make. That formulia is for 1/3 cup of each for 1 cup of finish.
13594 posts in 3249 days
#5 posted 11-14-2010 04:48 PM
i used watco for the box i did for my teacher
it surprised me
brush it on
and wipe of excess after 10 minutes
(it takes some rubbing ,
and two rags
so you don’t leave fingerprints)
and let dry overnight
then another coast
overnight dry again
then wax
came out good
any dust got rubbed off
easier than poly
don’t be afraid to rub it good
it gums as it dries
View CharlesNeil's profile
CharlesNeil
2262 posts in 3778 days
#6 posted 11-16-2010 08:22 PM
Arm R seal in satin sheen.. 3 or 4 coats and call it a day
View PurpLev's profile
PurpLev
8534 posts in 3556 days
#7 posted 11-16-2010 08:31 PM
any film type finish is a hardening oil – poly…etc.
depending on the age of your grandson I’d recommend a food safe finish such as salad bowl finish which is also a hardening oil and creates a film is applied several coats.
View hObOmOnk's profile
hObOmOnk
1381 posts in 4035 days
#8 posted 11-16-2010 10:00 PM
Hardening oils are those oils which polymerize or harden to form a protective film, usually when exposed to air.
The most common Hardening Oils (aka Curing Oils or Drying Oils) used in woodworking include:
  • Linseed Oil
  • Tung Oil
  • Walnut Oil
Oil-based varnishes are made by “cooking” together a drying oil and a resin (such as polyurethane, alkyd or phenolic). The resultant product is neither resin nor oil; it is varnish. It’s like cooking together milk, eggs and sugar to produce custard.
When a raw drying oil is mixed with an oil-based varnish, it is an oil/varnish blend, e.g. Danish Oil.
Finishing products that contain “Oil” in the name may not be a pure hardening oil, e.g. Danish Oil and Tung Oil Finish. In fact, some Tung Oil Finish products may not contain any real Tung Oil.
Caveat emptor…
-- 温故知新
