Will Epoxy hold Screws?
Forum topic by cag0331 posted 05-08-2017 04:44 PM 2489 views 0 times favorited 8 replies Add to Favorites Watch
View cag0331's profile
cag0331
13 posts in 696 days
05-08-2017 04:44 PM
Topic tags/keywords: epoxy west systems hole filling screw hole toothpicks wood glue
I’m trying to fill some screw holes in a shop jig that will need to be redrilled, and I’m wondering if epoxy (West Systems or even the stuff sold in the big boxes) would work for that application and hold the screws? Or is the toothpick and wood glue method the best for this application? Thanks!
8 replies so far
View waho6o9's profile
waho6o9
8356 posts in 2694 days
#1 posted 05-08-2017 04:45 PM
What is the jig made out of?
View jbay's profile (online now)
jbay
2583 posts in 1016 days
#2 posted 05-08-2017 04:48 PM
If you can’t drill it and plug it with a dowel, then I would go the toothpick and glue route.
cag0331
#3 posted 05-08-2017 04:52 PM
- waho6o9
It’s made out of Baltic Birch ply laminated to 1.5” and the holes I want to fill are on the edge.
waho6o9
#4 posted 05-08-2017 04:58 PM
For a jig application a plug might give you more strength in conjunction with glue or epoxy.
If possible a threaded insert may be useful as well.
Baltic Birch makes for a good jig. Good luck now
View DrDirt's profile
DrDirt
4451 posts in 3859 days
#5 posted 05-08-2017 05:12 PM
Yes epoxy works well. Folks use it to make mdf shelf pi jigs tougher as well as screw holes for de staco clamps
http://www.finewoodworking.com/2014/04/02/how-to-toughen-wood-with-epoxy
jbay
#6 posted 05-08-2017 05:39 PM
You should cut it out and mortise in a new piece, then pin it to be sure!
View them700project's profile
them700project
117 posts in 1135 days
#7 posted 05-08-2017 07:07 PM
I would think it would be better if the hole was undercut or threaded before filling it with the epoxy. that way the epoxy will hold in the wood. as for the strength of the epoxy i couldnt tell you
View shipwright's profile
shipwright
8064 posts in 2915 days
#8 posted 05-08-2017 08:04 PM
Actually, ..... the strongest way to get a screw to hold in wood is to overdrill the hole, fill with epoxy, and insert the screw. The positioning of the screw is facilitated by not overdrilling the whole depth.
Just epoxy-coating the screw before insertion in a proper fitting hole adds to the strength. Overdrilling makes it even stronger. The bigger the hole the stronger it gets until it reaches the tensile strength of the screw at which point the head is pulled off the screw.
To answer your question directly …. yes.
