Can I mix Titebond I & III?
« back to Joinery forum
Forum topic by Medici posted 05-08-2017 01:29 PM 1222 views 0 times favorited 16 replies Add to Favorites Watch
View Medici's profile
Medici
50 posts in 821 days
05-08-2017 01:29 PM
Topic tags/keywords: jig question clamp jointer joining milling veneering arts and crafts modern rustic traditional
Hey all.
So I was given (2) 1 gal. jugs of Titebond I from work, since they had a leaking hole in the top of the jugs. They were going to be hazmat’ed out and tossed, but I snatched them since they were both near full, for only $1 each.
I usually only use Titebond III, but was wondering if I mixed in Titebond I, if it would be sufficient for gluing different joints. I would use the III & I at a ratio of maybe 3:1, respectively. Is this a good idea, or should I call Titebond and ask?
Thanks!
P.S. – I am usually gluing butcher blocks, tables, and sometimes mortise joints.
16 replies so far
View HerbC's profile
HerbC
1792 posts in 3099 days
#1 posted 05-08-2017 01:36 PM
I wouldn’t mix the two glues…
Get a good container and put the TBI in it and use it for joints that don’t have to be resistant to moderate water exposure.
Good Luck!
Be Careful!
Herb
-- Herb, Florida - Here's why I close most messages with "Be Careful!" http://lumberjocks.com/HerbC/blog/17090
Medici
#2 posted 05-08-2017 01:52 PM
I wouldn t mix the two glues…
Get a good container and put the TBI in it and use it for joints that don t have to be resistant to moderate water exposure.
Good Luck-!
Be Careful!
Herb
- HerbC
Thanks for the input Herb. Any reason why you’d stay away from mixing?
View johnstoneb's profile
johnstoneb
3072 posts in 2412 days
#3 posted 05-08-2017 02:50 PM
For one if they are comnpatible the TBI will degrade the TBIII’s water resistance. So now you basically have TBI again.
Herb
Gave you some damn good advice if you don’t want to use it mix some together and see what happens.
-- Bruce, Boise, ID
johnstoneb
#4 posted 05-08-2017 02:52 PM
Herb
-- Bruce, Boise, ID
View JayT's profile
JayT
6010 posts in 2451 days
#5 posted 05-08-2017 02:53 PM
I wouldn’t mix the two either. The properties of the two glues are different, so that means the additives are different, as well. Mixing the two most likely will not give good results.
The best thing to do is to just call the company and see what they say.
-- In theory, there is no difference between theory and practice. In practice, there is.
Medici
#6 posted 05-08-2017 04:37 PM
For one if they are comnpatible the TBI will degrade the TBIII s water resistance. So now you basically have TBI again.
Herb
Gave you some damn good advice if you don t want to use it mix some together and see what happens.
- johnstoneb
I appreciate his advice; I just wanted more than “I wouldn’t mix the two together is all”, but thanks.
View gargey's profile
gargey
1013 posts in 1015 days
#7 posted 05-08-2017 04:49 PM
I wouldn’t mix the two together, because if you do they will react and make sarin gas that will kill everything within 200-300 feet and melt a hole in the ground all the way to the center of the earth.
View CharlesA's profile
CharlesA
3361 posts in 2037 days
#8 posted 05-08-2017 04:51 PM
I think you’ll end up with Titebond II if you mix them . . .
(I wouldn’t either, actually.)
5240 posts in 2733 days
#9 posted 05-08-2017 07:54 PM
It wouldn’t bother me to mix them, but I’m not sure why I would. TB I is a fine glue, quite useful without being mixed with TBIII.
View papadan's profile
papadan
3584 posts in 3608 days
#10 posted 05-08-2017 08:03 PM
Send them to me and I’ll mix them, I have a respirator so the gas wont get me and I really do want a hole that deep in my shop floor! Just use the TB1 for regular work and the TB3 for your cutting boards, just like they are designed for.
View Charlie H.'s profile
Charlie H.
323 posts in 890 days
#11 posted 05-08-2017 11:46 PM
You know this doesn’t have to be an all or nothing dealio.
Try mixing a couple tablespoons together and edge glueing a couple of short boards together and see how it works.
I don’t really like tite bond 3 so having a gallon of it sitting around would not do me any good.
If mixing it with tite bond 1 produced a product I liked well enough to substitute for tite bond 1 & 2 that’s what I would do.
-- Regards, Charlie in Rowlett, TX --------I talk to myself, because sometimes I need expert advice.---------
View MrUnix's profile
MrUnix
7107 posts in 2438 days
#12 posted 05-09-2017 12:03 AM
Just an opinion, but it seems like mixing the two would remove the best qualities of each. TBI dries a relatively light yellow/clear color that is better for hiding glue joints (and can be made virtually invisible). TBIII dries a light brownish color, which will emphasize glue joints, particularly on light colored woods. TBI is for interior use (not water-resistant), TBIII is water-resistant and suitable for indoor/outdoor use.
Mix the two, and you get a glue that is not water-resistant, and will dry with a darker color. Then you get into the whole open time and additive differences and how well they play together. I’d keep ‘em separate.
PS: Why did you have to pay $1 when they were just going to be ‘tossed’ anyway?
Medici
#13 posted 05-10-2017 04:33 PM
PS: Why did you have to pay $1 when they were just going to be tossed anyway?
- MrUnix
Because I work for a large company that needs to be convinced that it’s worth pay SOMETHING for it lol. I’m not complaining :P
View bonesbr549's profile
bonesbr549
1579 posts in 3307 days
#14 posted 05-10-2017 04:59 PM
First it will be a mistake and they will fail. Second, unless you are gluing a ton of stuff it will expire before you ever get close to using it. I remember a long time ago my local hardware had a sale 1/2 off a gallon of glue.
I ended up losing money as I did not use before it got old. Lesson learned, now I get only enough glue for a project.
:) If you a cabinet shop, then good deal, but I’d still not mix.
View waho6o9's profile
waho6o9
8539 posts in 2816 days
#15 posted 05-10-2017 05:01 PM
I just called them up and they said no.
PRODUCT QUESTIONS
Technical Support
Phone (800) 347-4583
Fax (614) 445-1295
e-mail Technical Support
“Just an opinion, but it seems like mixing the two would remove the best qualities of each.”
Mr.Unix nailed it, that’s exactly what Tech support told me.
Congrats ^^
