Replacement Brace Jaws
« back to Hand Tools forum
Forum topic by BPatterson posted 05-07-2017 05:38 PM 730 views 0 times favorited 6 replies Add to Favorites Watch
View BPatterson's profile
BPatterson
43 posts in 1721 days
05-07-2017 05:38 PM
I have two braces, one is a Miller’s Falls I picked up on Craigslist and has been hanging on the wall for a while as decoration and the other was my late grandfather’s and was recently given to me. I have recently gotten much more interested in using hand tools so I was planning to restore them and get them in good working order. The problem is that both of them seem to be missing the jaws. Since both were missing the jaws I assumed that this was a common issue but after searching for a while I haven’t really found any posts about it or replacement jaws available. Do you guys know any resources for replacement jaws? Also is this a common issue or do I just have particularly bad luck?
Thanks!
Brandon
-- Brandon ~ Aim Small, Miss Small
View BlasterStumps's profile
BlasterStumps
863 posts in 560 days
#1 posted 05-07-2017 05:46 PM
Oh, I wouldn’t say it’s bad luck. After all, you now have your Grandfather’s drill. That’s way cool. Hang on to it.
What I would suggest for the jaws is to watch Etsy or Ebay or Habitat, etc. for same same drill to get the jaws to replace those from your Grandfather’s drill. For the one from Craigslist, keep it for parts possibly or try to find another one like it also and make it whole again using the parts from a donor drill.
Edit: By the way what is the overall condition of both the drills you have now? Maybe someone robbed the jaws from them because there was another problem with the tool. I would check them both over carefully to see what the conditions are.
-- "I build for function first, looks second. Most times I never get around to looks." - Mike, western Colorado
BPatterson
#2 posted 05-07-2017 06:18 PM
Thanks! That is good advice. I didn’t notice any issues when looking at them before but I will try to post some pictures a little later.
View Loren's profile
10477 posts in 3769 days
#3 posted 05-07-2017 06:59 PM
#4 posted 05-07-2017 07:02 PM
I have a couple of braces but have never
encountered missing jaws. I don’t know
if it’s a common problem but generally
the jaws will fall out if you take the nut
off the chuck.
Sometimes the jaws will be deeply retracted
into the brace chuck.
View diverlloyd's profile
diverlloyd
3029 posts in 1978 days
#5 posted 05-07-2017 08:06 PM
do you have an pic of what you need braces around here are very cheap. so if you have a pic i can look around for you.
View Tim's profile
Tim
3812 posts in 2082 days
#6 posted 05-07-2017 10:17 PM
It’s definitely not very common, I can’t recall any of the hundred or more braces I’ve seen with missing jaws, but I guess it’s possible I didn’t notice.
If you post pictures people can help you identify them and the specific chuck style and hopefully help get what you need.
