Converting an old table saw into a router table
Forum topic by Blakep posted 11-12-2010 04:34 PM 8370 views 0 times favorited 7 replies Add to Favorites Watch
View Blakep's profile
Blakep
232 posts in 2765 days
11-12-2010 04:34 PM
I have an old cheap table saw that has been burnt up for several years. It is a cheap skil brand I think. I would like to make a router table out of it. Has anyone ever done this or have any advice on doing this?
7 replies so far
View PurpLev's profile
PurpLev
8534 posts in 3612 days
#1 posted 11-12-2010 04:38 PM
I actually was considering doing the exact same thing – picking up a burnt table saw from someone that just wants to get rid of it, and using it as a base for a router table.
My thought was to use the blade raising mechanism to lift and lower the router, and just put an insert on top of the table top.
I never did get to do it as I just built a router table from scratch using things I had at hand, but I think it’s a great idea if you can make it work!
View Gregn's profile
Gregn
1642 posts in 2947 days
#2 posted 11-12-2010 05:03 PM
Not saying it can’t be done, but might be impractical for access purposes as you would have to go around to the back for access. Depending on the model of table saw you might be cramped for space with the router. You might remove the top and mount it into a base to compensate for those problems. Just my thoughts. Although before I got my scroll saw I did convert an old bench top to mount a jig saw for a makeshift scroll saw.
Blakep
#3 posted 11-12-2010 05:03 PM
My only concern is mounting the router to the table. How would you go about cutting it for a plate or how would you attach the router?
PurpLev
#4 posted 11-12-2010 05:30 PM
if it’s a skil table saw, I assume the top is aluminum and can easily be cut with a metal cutting blade in a jigsaw, hacksaw, or carbide bit in a router. be careful though – those metal chips are mighty hot when cut though and can fly all over the place – protect yourself FIRST.
like I said – I dropped the idea since there it was just easier building a router table from scratch, but you’d have to take the motor off with the arbor, and see what you have to work with. depending on the blade/motor mount you’d have to figure out a way to either mount the router directly to it, or build an aux holder for the router, or take the entire thing off all together and custom build something from the ground up.
Gregn
#5 posted 11-12-2010 05:33 PM
You would need to make a steel mounting plate to mount the router to the top. 1/8” steel plate should be enough for a mounting plate. Mounting to the top might be tricky depending on what the top looks like from underneath. You may need to drill mounting holes through the top and countersink for the screw heads to be flush with the top.
View Kent Shepherd's profile
Kent Shepherd
2718 posts in 3249 days
#6 posted 11-12-2010 06:16 PM
I did that to an old Craftsman years ago. After removing the trunnion,I took the cast iron top to a machine shop and had it milled flat underneath to accept the router. I ended up overlaying the top with a laminated top, so I lost some of the height of the router bit. At that time, there weren’t all the accessories available for router tables.
Looking back, I would do it differently. You could, with a jig saw, cut a round hole in the saw top bigger than the router. Then add a top over the saw top with a regular router plate. Then, the only advantage to the idea, is you have the base of the saw for a stand. I’m not sure it’s worth the trouble, but it will work.
-- http://shepherdtoolandsupply.com/
View hhhopks's profile
hhhopks
651 posts in 2340 days
#7 posted 03-04-2012 05:41 PM
Makesure your table top is good to begin with.
Flat/level to personal spec.
-- I'll be a woodworker when I grow up. HHHOPKS
