new to card scrapers
Forum topic by LumberNerd posted 11-12-2010 08:59 AM 1656 views 0 times favorited 13 replies Add to Favorites Watch
View LumberNerd's profile
LumberNerd
3 posts in 2676 days
11-12-2010 08:59 AM
I’ve decided to give card scrapers a try, the look like they would be extremely useful and give a very nice finish.
so this brings me to my question. I’m sitting here with the lee valley catalog and I’m not sure which one I need. The sizes are .4mm .6mm .8mm and 1mm. It is mentioned in the catalog that the 1mm is suitable for paint removal, so I assume this one would be too thick for fine woodwork. I would like to do both some heavier scraping, and some finer finish scraping as well. Will an in between size work well for both jobs or should I get the .8 and .4 and use the different ones for the different jobs?
13 replies so far
View live4ever's profile
live4ever
983 posts in 2917 days
#1 posted 11-12-2010 09:24 AM
I have a “standard” one from some random brand and it’s 0.8. It does everything I need it to do so I don’t think you need to bother with more than one unless you reeaaaally get into scraping.
You will also need a mill file (10 in.) and a burnisher, as scraping edges need to be refreshed often. There are lots of ways to sharpen and maintain the edge on scrapers, but almost every method needs the file, some type of abrasive (sandpaper, diamond stone, etc.), and a burnisher.
View KnickKnack's profile
KnickKnack
1088 posts in 3474 days
#2 posted 11-12-2010 09:56 AM
Strangely enough, I bought a card scraper yesterday too – I was amazed to see it in the local DIY shop so I snapped it up.
Anyways – I’ve looked at some videos, and I’m a bit confused about the “burnisher” – the last video I looked at it looked like a screwdriver. Since I don’t have much hope of finding the “official” thing – will a screwdriver do? Or what might be better?
-- "Do not speak – unless it improves on silence." --- "Following the rules and protecting the regulations is binding oneself without rope."
View olddutchman's profile
olddutchman
187 posts in 3843 days
#3 posted 11-12-2010 01:00 PM
In My experience, the burnisher is a very hard piece of steel. and can be slid along the edge of the scraper to roll the edge. If careful, I have used a file tong, and worked the edge with that. Cards can be made from an old saw by filing the teeth down, and filing the edge very straight. I have had good success by doing that. A sale, can usually find an old saw laying around, and the handle used for another project , or a replacement on Your own saw.
-- Saved, and so grateful, consider who Created it ALL!!!
View dbol's profile
dbol
136 posts in 2905 days
#4 posted 11-12-2010 01:39 PM
Your burnisher can be a screwdriver or a router bit or any piece of steel that is polished and a harder metal than your card scraper.
18615 posts in 4068 days
#5 posted 11-12-2010 01:47 PM
can’t answer your question but here is a great resource (video) for the tool (posted by Blake, here, about 3 years ago.
View Geedubs's profile
Geedubs
143 posts in 3137 days
#6 posted 11-12-2010 02:00 PM
Just FYI to LJ’s, it looks like Woodcraft is going to have their basic set of scrapers available on Black Friday for half price…as long as supplies last. I think the price is $7.99 for a set that normally runs $15.99. I share this information hoping you won’t get there before I do.
-- Todos los dias aprendemos algo nuevo.
View Gene Howe's profile
Gene Howe
10137 posts in 3336 days
#7 posted 11-12-2010 03:01 PM
Regarding scraper sharpening, some fellow, in a video, showed his method. He simply ran his scraper across a mill file and didn’t bother with the burnisher. I tried it and it works just fine. You don’t need a lot of pressure on the scraper, just run it along the file at 90 deg. until you can feel a curl forming.
The curl doesn’t last quite as long but, it only takes 4 swipes over the file to restore the curl.
When I used to burnish, I used an old round butcher knife sharpener.
LumberNerd
#8 posted 11-12-2010 03:41 PM
alright looks like I’m ordering the .8, from the videos I had seen it seemed like each one is quite versatile. I’m very exciting now, I can’t wait to get my first card and give this a try, especially since I just tore apart a skid and got a nice pile of maple I can’t wait to use!
View richgreer's profile
richgreer
4541 posts in 2982 days
#9 posted 11-12-2010 04:00 PM
The round shaft of a lathe cutting tool works great for burnishing. I use the shaft of my bowl gouge.
#10 posted 11-12-2010 04:13 PM
LumberNerd
#11 posted 11-12-2010 06:40 PM
Alright, I got impatient and decided I could make a scraper myself. So I took a hand saw I don’t ever use and cut a 2”x6” chunk out of it with the reciprocating saw. After grinding it straight and filing it I was able to take some fine shavings and get some saw dust as well, but nothing more, and fairly inconsistently. I attempted to the shaft of a router bit as a burnisher but with very limited results. Is my problem just technique, equipment, or should I just be patient and order one?
Gene Howe
#12 posted 11-12-2010 07:08 PM
Debbie,
That’s it!
Thanks.
View Walt's profile
Walt
245 posts in 2746 days
#13 posted 11-12-2010 08:47 PM
Gedubs thanks for the heads up on the scrapers. I will be at the store bright and early and will most likely get one before you since I live in Delaware. Our Sun will be up before yours :)
-- Walt Wilmington Delaware, http://waltlumley@yahoo.com
