Forum topic by dvhart | posted 11-12-2010 06:20 AM | 1263 views | 0 times favorited | 9 replies | ![]() |
I’m building my son a bed and the plans call for 1-1/8” stock for the rails. My local supplier offers 4/4 and 8/4, the former being to small, the latter being much to large. I don’t have a bandsaw and I’d rather not have to plane 8/4 stock down to 1-1/8”. I’m looking at building his bed out of pine to match an existing dresser. Should I be able to find some 1-1/4” stock that I can mill down, or do I have to bite the bullet and plane some 5/8” off the 8/4 stock? -- Darren |
9 replies so far
#1 posted 11-12-2010 06:27 AM |
Do you see any harm in simply modifying the plan, and going with the 4/4 ? -- -- Neil |
#2 posted 11-12-2010 06:32 AM |
You can certainly resaw on the table saw. Or you may want to consider an enginnering change and go with one inch or even 1 1/2 inch. Just depends on what is available to you. You have to wonder if the designer derived his data from actual structural aplication testing. I don t think that 1/8 inch would be critical criteria. Good luck JB |
#3 posted 11-12-2010 06:32 AM |
@Neil: I did this on a cherry bed I built with a friend and it turned out fine (http://lumberjocks.com/projects/29495). We used 1/2” plywood for the panels instead of the 3/4” it called for to account for the thinner rails. I’m concerned about using the thinner stock for the side rails (nearly 80” long) with a softer wood like pine. -- Darren |
#4 posted 11-12-2010 07:08 AM |
As cabmaker said, a table saw would do the trick. A thin kerf blade would help using this method. |
#5 posted 11-12-2010 03:36 PM |
Since you are making it out of pine, did you consider using top grade kiln dried construction lumber? I just bought some shorts at Menards. They have an area where they get rid of offcuts at very low prices. I got some great 2” x 8” (actually 1-3/8” x 7-1/2”) that were 4 feet long. You probably won’t be able to get offcuts since you need 80” long pieces. -- "A goal without a plan is a wish." |
#6 posted 11-20-2010 03:52 AM |
@dvhart: Your link does not seem to work? |
#7 posted 11-20-2010 04:28 AM |
@sandhill, ugh, the website included the ) in the address. Try this one: http://lumberjocks.com/projects/29495 -- Darren |
#8 posted 11-20-2010 09:11 AM |
If you’re using bought plans it’s probably sized that way to use construction grade lumber. A 2x is easy to get to 1 1/8 with a couple of passes through a planer. I’m with Ampeater. Check your local lumber yard or BORG and get some good construction grade. Pick your pieces carefully! Alternatively, you could laminate 2 pieces together. -- Nate, thegaragestudio.etsy.com |
#9 posted 11-20-2010 10:15 PM |
Thanks for all the ideas everyone. The plans I’m using don’t specify the wood species, but the example was in cherry – so definitely not based on construction grade lumber. I found a local supplier that carried 5/4 poplar, and they planed it all down to 1-1/8 for a very reasonable fee. This saves some wear and tear on my planar, leaving me to just do a final finish pass – if anything at all. I was originally planning on pine because it is inexpensive and it’s what I thought the piece I want to match was made of. As it turns out, the piece I’m matching is made of a variety of things, including MDF with faux grain. I’ll be using a gel stain, so the pigment (vs dye) will muddy the grain of whatever I use. Poplar will hold up a bit better than pine and still doesn’t break the bank. Wish me luck :-) -- Darren |
Forum | Topics |
Woodworking Skill Share
12035 |
Woodturning
2110 |
Woodcarving
431 |
Scrollsawing
340 |
Joinery
1372 |
Finishing
4910 |
6698 |
28076 |
CNC Woodworking
212 |
Hand Tools
5413 |
Jigs & Fixtures
1421 |
Wood & Lumber
6237 |
1388 |
Focus on the Workspace
2154 |
1187 |
Woodworking Trade & Swap
4759 |
LumberJocks.com Site Feedback
2201 |
Coffee Lounge
8847 |
