Painting Cast Iron
Forum topic by jonnybrophy posted 05-05-2017 11:41 PM 545 views 0 times favorited 6 replies Add to Favorites Watch
View jonnybrophy's profile
jonnybrophy
160 posts in 729 days
05-05-2017 11:41 PM
Topic tags/keywords: question jointer spray gun finishing refurbishing
How do you do it?
The rust on my jointer is all wire brushed off, and i masked off all the machined surfaces.
The paint is in decent condition for painting over, so no need to strip it.
My question is, how many coats? and what do i do after the paint? lacquer, poly,nothing?
Also, i dont have a sprayer, so is spraying from the can ok?
Thank you all so much for helping me through this restoration! I am eternally grateful.
-- "If she dont find ya handsome, she better find ya handy"
View MrUnix's profile
MrUnix
6887 posts in 2317 days
#1 posted 05-05-2017 11:44 PM
Wipe down with dilute phosphoric acid solution, followed by mineral spirits. Then brush on at least two coats of a good quality oil based enamel.
jonnybrophy
#2 posted 05-05-2017 11:48 PM
- MrUnix
I did not understand most of that,
what i did understand, I dont have
I have a can of black spray paint + primer (2 in 1), also, i have turpentine
is phosphoric acid for cleaning? is it absolutely necessary? if so, its only $12 at home depot
MrUnix
#3 posted 05-06-2017 12:13 AM
You plan on painting the whole jointer with one can of black spray paint?!?
Phosphoric acid will remove any remaining hidden bits of rust and prep the surface for good adhesion. You can get a gallon of the stuff pretty cheap at the BORG as you mentioned. Dilute 50/50 with distilled water, wipe it on, wait a minute or two, then wipe off. I then like to wipe everything down with mineral spirits just to remove any residual contaminates. Preparation is 99% of painting. And no, it’s not absolutely necessary – but you may wind up with a less than ideal paint situation down the road… like peeling paint, or paint that easily chips off when hit.
I also like to brush on the enamel, as it provides a thicker, more durable surface. Primer is not necessary.
jonnybrophy
#4 posted 05-06-2017 01:02 AM
Phosphoric acid will remove any remaining hidden bits of rust and prep the surface for good adhesion. You can get a gallon of the stuff pretty cheap at the BORG as you mentioned. Dilute 50/50 with distilled water, wipe it on, wait a minute or two, then wipe off. I then like to wipe everything down with mineral spirits just to remove any residual contaminates. Preparation is 99% of painting. And no, it s not absolutely necessary – but you may wind up with a less than ideal paint situation down the road… like peeling paint, or paint that easily chips off when hit.
- MrUnix
Thank you so much, that was the perfect explanation!
Ill head to home depot tomorrow, also, i plan on color matching the jointer and cabinet so i can get as close to the DELTA color as possible.
The black is only for the back of the fence area, and the very bottom of the cabinet.
Can i just spray the paint out in a separate container and then brush it on?
also, what the heck is a BORG?
View Dark_Lightning's profile
Dark_Lightning
3221 posts in 3227 days
#5 posted 05-06-2017 03:15 AM
Big Orange Retail Giant. 8D I’d recommend buying even a pint of oil based enamel instead of draining a spray can. You’ll get more paint that way. If you want to spray, use the Rustoleum “professional grade”, or whatever it’s called. It works really well. It comes in a bigger can, 14 or 16 oz instead of 12 oz.
-- Random Orbital Nailer
View Gentile's profile
Gentile
308 posts in 1936 days
#6 posted 05-07-2017 04:03 AM
I’ve been using Rustoleum for a few machine projects, a lathe, a drill press, and a tool box.
Primer first, then several more of the color you choose. I live in a dry climate, and rust coming through hasn’t been an issue fo me. Rustoleum offers several shades of grey.
-- "I cut it twice and it's still too short"
