Door trim question
Forum topic by RobS888 posted 05-05-2017 06:05 PM 622 views 0 times favorited 8 replies Add to Favorites Watch
View RobS888's profile
RobS888
2455 posts in 1898 days
05-05-2017 06:05 PM
Hey,
I’m trying to trim out a bathroom door at the end of a hall. When I started testing pieces it became obvious that someone had done some work to hide an error. The door is almost 5/8 taller on one side than the other. That seems to have been done to compensate for the door frame being out maybe an inch.
If I try to have a consistent reveal it looks really lopsided. In the picture I have it close to level, the right side should go up a bit to be level. the reveal almost disappears on the left.
So should I go for the consistent reveal, or more level?
Maybe tear it out and start again.
-- I always suspected many gun nuts were afraid of something, just never thought popcorn was on the list.
8 replies so far
View Loren's profile
10476 posts in 3701 days
#1 posted 05-05-2017 07:13 PM
If I had the time I would rip out the top board and
try to move it up a little on the right. You have a
board in the way so I can’t see if there are spacers
in there that can be removed. If they can be, sometimes
some hard whacks can persuade a nailed board
a little.
Moving the board down on the left with a prybar
might work as well… or pound wedges in to
move it. Of course you’d probably have to rip
off the trim on the other side as well.
RobS888
#2 posted 05-05-2017 07:39 PM
board in the way so I can t see if there are spacers
a little.
move it. Of course you d probably have to rip
- Loren
There is a 1/2 inch shim on the right side.
I’ll get a pic of the bare opening.
View Hammerthumb's profile
Hammerthumb
2862 posts in 2028 days
#3 posted 05-05-2017 08:00 PM
Take it apart and re-shim the door casing to get it plumb.
-- Paul, Las Vegas
View jerryminer's profile
jerryminer
935 posts in 1494 days
#4 posted 05-05-2017 08:38 PM
Pull off the casing and re-hang the door so the head jamb is level.
Barring that, maybe taper the top casing so the top is near level and the reveal is near equal?
View JBrow's profile
JBrow
1365 posts in 973 days
#5 posted 05-05-2017 08:45 PM
RobS888,
Hammerthumb’s method is probably the best way to fix the problem. But if re-hanging the door plumb and square is not part of the plan, then ripping a slight taper on the edge of the head casing that is toward the door could leave a consistent reveal. The side casing could be mitred to match the taper on the head casing. This would leave a consistent reveal around the door while keeping the head casing level. I would think that it would require a close inspection to see the fix since the taper would be very slight.
jerryminer posted while I was composing. As you can see, I like his ideas.
View mike02130's profile
mike02130
167 posts in 725 days
#6 posted 05-05-2017 10:27 PM
Split the difference
-- Google first, search forums second, ask questions later.
RobS888
#7 posted 05-06-2017 03:18 AM
- mike02130
That’s what I’m leaning towards, slight angle and slightly off reveal.
View oldreddog's profile
oldreddog
165 posts in 2386 days
#8 posted 05-08-2017 11:28 AM
When in doubt rip it out….
-- oldreddog
