grinder wont turn wheels
Forum topic by Karda posted 05-05-2017 05:59 PM 592 views 0 times favorited 11 replies Add to Favorites Watch
View Karda's profile
Karda
1303 posts in 724 days
05-05-2017 05:59 PM
Hi, I put a new wheel on my home built grinder then took it off to check on why it wobbled. when I put it back on the motor would not turn the wheels. I totally loosened the wheels and it works fine, also with out the wheels. I put the new wheel on several days ago and it worked fine. What am I doing wrong. here are some pics of the grinder
11 replies so far
View jonnybrophy's profile
jonnybrophy
160 posts in 782 days
#1 posted 05-05-2017 06:05 PM
Is it possible that when tightening the wheels, the middle section is pinched together, and the wheels cant turn freely?
Take one wheel off, then tighten the other wheel
if it runs, then thats your problem
p.s.-can’t see the assembly real well, can i have a pic with some more light on the wheel area?
-- "If she dont find ya handsome, she better find ya handy"
View HokieKen's profile
HokieKen
6538 posts in 1309 days
#2 posted 05-05-2017 06:17 PM
In your second pic, it looks like your belt is way out of line. That’s probably not the source of your issue but it’s going to cause some inefficiency in your set up and your going to chew through belts faster than normal.
-- Kenny, SW VA, Go Hokies!!!
View ToddJB's profile
ToddJB
8261 posts in 2300 days
#3 posted 05-05-2017 07:11 PM
If the belt’s too tight it can bog your motor down too much for it to spin
-- I came - I sawed - I over-built
Karda
#4 posted 05-05-2017 09:20 PM
I know the belt is out of line. its not the belt that is not to tight. I,ll check the pully and the stop wheel don,t know what else it could be
View Nubsnstubs's profile
Nubsnstubs
1414 posts in 1900 days
#5 posted 05-05-2017 09:48 PM
Karda, what is the HP rating on the motor? If it’s a 1/4 hp, combined with the belt misalignment, too tight a belt, and those large heavy wheels, it just might be too much for the motor.
I know you stated it wasn’t too tight. What is your guide for achieving proper belt tension?
So you know the belt is out of alignment, what’s your excuse for not fixing it? ...... Jerry (in Tucson)
View MrUnix's profile
MrUnix
7001 posts in 2369 days
#6 posted 05-05-2017 10:04 PM
Well, since it’s a ‘homemade’ grinder, nobody should know more about it than you – unless you weren’t the one who made it. From the description, it sounds like the grinding wheel is contacting the housing – perhaps just missing a spacer or improperly placed stop collar. Would have to have a better picture to give any real advice.
View Picklehead's profile
Picklehead
1043 posts in 2099 days
#7 posted 05-05-2017 10:14 PM
So you know the belt is out of alignment, what s your excuse for not fixing it? ...... Jerry (in Tucson)
- Nubsnstubs
Somebody needs a nap.
-- You've got to be smarter than the tree.
Karda
#8 posted 05-05-2017 11:48 PM
the belt wasn’t fixed because I new it would be a major undertaking to fix it. I just spent a half hr tring to pull the pully, can’t get it. I don’t even think there is room for a wheel puller. there is some kind of collar behind the pully. I moved the motor but didn’t do much good but I can move the arbor over a little. The wheels turn, I moved the shaft and got the stop collar to tight moved it over works fine now
View Woodknack's profile
Woodknack
12397 posts in 2550 days
#9 posted 05-06-2017 12:10 AM
Nubsnstubs
#10 posted 05-06-2017 12:52 AM
- Nubsnstubs
- Picklehead
OK, I took a nap. Yep, I still feel the same. No excuse not to fix things that are not right. They can lead to problems and more costs later. . That’s why you fix them now…..... Jerry (in Tucson)
Karda
#11 posted 05-06-2017 02:22 AM
my previous post I fixed it, now the belt
