shiplap joint on a curve-need suggestions on how to do
Forum topic by kevinw posted 11-11-2010 04:33 PM 2326 views 0 times favorited 5 replies Add to Favorites Watch
View kevinw's profile
kevinw
191 posts in 3702 days
11-11-2010 04:33 PM
Topic tags/keywords: shiplap routing cross joint suggestion need help
I am making a contemporary looking curved cross and need some suggestions on how best to do a shiplap joint
where the cross members fasten together since the intersecting points are not straight. One friend suggested freehand routing but once the first shallow pass is made I wouldn’t have a reference point and if I plough the entire depth out at once I fear it would tear out or be too difficult to control. If I hand chisel it I am fearful it will have a choppy straight edged look rather than the smooth curve I am after
See the attached sketch for an idea of what I mean.
Thanks.
-- Kevin, Blue Springs, MO
5 replies so far
View 489tad's profile
489tad
3350 posts in 2974 days
#1 posted 11-11-2010 05:48 PM
Kevin, If I were to use chisels I’d razor knife the edge first. I probably could not cut that curve cleanly with chisels. I’d would make a router templet with the curve pattern. Hope that helps. Good luck, Dan
-- Dan, Naperville IL, I.G.N.
kevinw
#2 posted 11-12-2010 06:26 AM
A router template might be best but not sure how to transfer the curves out and keep it correct. Any suggestions? Maybe plot a bunch of points out from the line at the correct distance and then connect them with a french curve? I am doing a prototype out of some scrap pine, so have room for a few errors (not that I ever make any ; )
View cabmaker's profile
cabmaker
1719 posts in 2771 days
#3 posted 11-12-2010 06:39 AM
This is where an overhead pin router shines. Freehanding with a router (heavier the better) should do well.
View Broglea's profile
Broglea
684 posts in 3053 days
#4 posted 11-12-2010 07:06 AM
Kevin – You might consider fastening your two blanks together using a lap joint before you begin shaping the two pieces.
View FredG's profile
FredG
139 posts in 3659 days
#5 posted 11-12-2010 07:10 AM
Hi Kevin,
The main idea is using a palm router with a bushing 3 times the size of the router bit.
First (1) route with the bushing on thin mdf through the mdf.
That leaves you with a template in which you can route the exact shape (2).
The larger metric bushings come in the sizes 30mm, 27mm, and 24mm. 30 mm of course the most stable.
-- Fred
