| Forum topic by Brent Livingwell | posted 285 days ago | 616 views | 0 times favorited | 9 replies | ![]() |
285 days ago |
Question: I find myself using a lot of hardwood covered plywoods and spending a lot of time glueing hard wood strips to cover the exposed plywood. In my earlier projects I biscuited 3/4inch stips onto the ply. I found that my biscuit joiner cut holes that were a little larger than the biscuit and I would have to futz around tring to get the ply and the strip perfectly alligned during the clamp up. Since then, I found that i like the look of thiner strips i.e. 1/4 or less, and I can no longer use biscuits. Now I just glue on the strips and the task of alligning the two pieces is even harder, especially when the strip is got a slight crook in it as often happens when the fiber tenson is released when I cut the strips. Does anyone have a fast, effecive, or precise method of laminating hardwood strips to plywood? -- Things of the greatest worth are from the Earth. Ben Harper |
