HELP blotchy varnish with earlex 6000
Forum topic by NorthernT posted 05-04-2017 06:32 PM 601 views 1 time favorited 12 replies Add to Favorites Watch
View NorthernT's profile
NorthernT
4 posts in 536 days
05-04-2017 06:32 PM
I am getting a blotchy finish with hirschfields one hour finish. What am I doing wrong? Please help.
12 replies so far
View CharlesNeil's profile
CharlesNeil
2436 posts in 4019 days
#1 posted 05-04-2017 06:54 PM
This should be interesting .. you have alot of blotch control experts on here.. as well as sprayer experts …
View jbay's profile
jbay
2681 posts in 1047 days
#2 posted 05-04-2017 07:04 PM
Charles, tsk, tsk, tsk, Your a bad boy! lol
5097 posts in 2641 days
#3 posted 05-04-2017 07:09 PM
Well, with some woods any oil finish will cause blotch and some are a lot worse than others. What is the wood, and is it possible to get a pic of the effect?
NorthernT
4 posts in 536 days
#4 posted 05-04-2017 07:16 PM
Its pine
NorthernT
4 posts in 536 days
#5 posted 05-04-2017 07:45 PM
Pine
View BurlyBob's profile
BurlyBob
5918 posts in 2414 days
#6 posted 05-04-2017 08:24 PM
I just bought that Earlex 6000. Do you think it’s the mix, or the varnish? I’ll be interested to hear the final results on this topic.
View OSU55's profile
OSU55
1869 posts in 2138 days
#7 posted 05-04-2017 09:09 PM
It might be blotchy but I can’t see through the orange peel and dry spray to the surface.
View ClammyBallz's profile
ClammyBallz
447 posts in 1285 days
#8 posted 05-04-2017 09:25 PM
Sand it back and apply a thinner coat. It should be wet, but not puddle. Do you have an exhaust fan?
#9 posted 05-04-2017 09:29 PM
Like OSU55, I can see orange peel, but not blotch. Is it possible you are calling the orange peel (un-smooth finish) blotching?
NorthernT
4 posts in 536 days
#10 posted 05-04-2017 09:55 PM
Ok whatever it is orange peel, blotchy whatever. I just want a smooth finish. I need to sand it down and apply a thinner coat. I do have a fan blowing out.
View Rich's profile
Rich
3668 posts in 738 days
#11 posted 05-04-2017 10:10 PM
I assume that’s a test piece, not the final project that you are spraying on. Like Fred and OSU55 said, that’s orange peel, not blotch. Generally, orange peel comes from finish that is too thick. Take Clammy’s advice and thin out the finish a bit.
There are videos out there that might help you get started, but I found that practice is what will get you there. Variables such as the species and surface prep of the wood, the finish you’re spraying, temperature and humidity all affect the finish, and no one setup will work for every situation.
Be sure to be practicing on sample boards of the same type of wood and surface preparation as your final project. Sand to the same grit, seal coat, stain, whatever should be the same, since oils in the stain can affect how some topcoats behave. Take copious notes too. For HVLP systems, adjusting the air and fluid flow rates change how the finish will behave as well.
View Andybb's profile (online now)
Andybb
1288 posts in 752 days
#12 posted 05-05-2017 03:04 AM
Like RichTaylor said practice boards of the same material are a must. Looks to me like a bad air/fluid/thickness issue. First spray just plain water on cardboard to get close to the mix, then spray the cardboard with your finish, then some practice boards that are prefinished with whatever your project is done with. (stain, oil etc) You can just wipe off the practice boards with a rag and try again before it drys. Not to worry. I think we’ve all had similar issues. If that is your actual project just sand it off and start over.
-- Andy - Seattle USA
