Brad point or conical point bits for drill press use
Forum topic by groland posted 05-04-2017 03:12 PM 621 views 0 times favorited 7 replies Add to Favorites Watch
View groland's profile
groland
187 posts in 3468 days
05-04-2017 03:12 PM
Topic tags/keywords: brad point or conical point bits in drill presses
I have recently purchased my first new drill press and it has prompted this question. Is there any preference or benefit to using standard conical-point bits as opposed to brad point bits in a drill press?
Thanks,
George Roland
7 replies so far
View UpstateNYdude's profile
UpstateNYdude
917 posts in 2039 days
#1 posted 05-04-2017 03:14 PM
Brad points usually have spurs that will cut a much cleaner hole in wood. Conical points are best used when working with metal.
-- Nick, “I am always doing what I cannot do yet, in order to learn how to do it.” – Vincent Van Gogh
View BurlyBob's profile
BurlyBob
5661 posts in 2321 days
#2 posted 05-04-2017 03:18 PM
I use brad point and forstner bit for a nice clean hole. Standard bit when I just need a hole and don’t git a rip what it looks like. One trick I learned sometime ago and have found it very valuable is to use a square point awl for a small pilot hole no matter which drill bit I use.
View LittleShaver's profile
LittleShaver
339 posts in 675 days
#3 posted 05-04-2017 03:33 PM
+1 on previous postings. Brad points and forstners except for metal.
-- Sawdust Maker
View Woodknack's profile
Woodknack
12084 posts in 2436 days
#4 posted 05-04-2017 03:37 PM
Conical = twist bit. You’ll want some eventually. Keep an eye on the hot deals thread and snag a high quality US made set at chinesium prices.
View JayT's profile
JayT
5731 posts in 2267 days
#5 posted 05-04-2017 03:57 PM
If you need a very accurate and clean hole, use a brad point.
If you just need a hole, use a twist bit. No reason to wear out and dull the brad points unnececessarily.
View oldnovice's profile
oldnovice
6952 posts in 3424 days
#6 posted 05-04-2017 08:45 PM
We have fractional sets, number sets, and don’t forget about the letter set of bits!
Aren’t you glad you are a woodworker ….... and all you really need are fractional?
But what type of fractional?
  • Twist bit’s
  • Auger bits
  • Nail buster auger bits
  • Ship auger bits
  • Forstner bits
  • Self feed bits
  • Bradpoint bits
  • Spade bits
View Loren's profile
10476 posts in 3704 days
#7 posted 05-04-2017 09:57 PM
I grind my own brad bits from standard twist drills.
https://youtu.be/VcwOBL0tTbc
