Forum topic by Matt | posted 11-11-2010 03:43 AM | 1352 views | 0 times favorited | 4 replies | ![]() |
Got another question on a roll top desk I plan on building. I’ll try to describe this the best I can but. If you take a look at the link I provided. Now on the back section of the top the middle stile carries up to the top of the hutch. Now the tambour needs a groove to ride in. How does the groove carry on through the panel. http://www.amishshowroom.com/index.php?main_page=popup_image&pID=611 I hope you guys understand what I mean. :p -- Hold on! Let me get the board stretcher! |
#1 posted 11-11-2010 03:52 AM |
all the shelving need to be clear of the top -- david - only thru kindness can this world be whole . If we don't succeed we run the risk of failure. Dan Quayle |
#2 posted 11-12-2010 04:26 PM |
Norm built a roll-top desk (not as fancy as that one). His show explains how the tambour is independent of the structure except where it’s captured in the track on the sides. It has to roll down behind the cabinetry along the back. -- You can't control the wind, but you can trim your sails |
#3 posted 01-20-2012 03:51 PM |
Has anyone had trouble with the tambour. I bought the router bit set, but it doesnt seem to roll right. |
#4 posted 01-20-2012 04:54 PM |
I recently installed a tambour in an audio booth I made. You can see it here in the second and third pictures (ignore the dust) http://lumberjocks.com/projects/55091 In my case, I bought a pre-made tambour top from Woodwaves. I think that is the way to do it. I’m very happy with the top I bought and how well it works. I spent about $130 for a tambour top that is 54” wide and 30” deep. Money well spent. I still needed to put an end piece on the top and cut the tracks for it to run in. The handles and lock are connected to the end piece I put on. The handles are not essential, but they are nice. I also needed to deal with the mechanical aspects. There is a slot in the back of the work surface and the top runs down the back wall below the work surface. I needed to make a track for the back wall and install a stop so it only opened so far. Also – you cannot have any wall based support for the work surface under the tambour area. I ran a support brace under the front of the work surface along the length of the work surface. That brace may not have been necessary, but I wanted to be certain we would have no sagging. 54” is a relatively long span. Finally, if you are smarter than me (most people are), you would not install an electrical outlet in the area that will be covered up when the tambour top is opened. I put the electrical outlet in early in the project and put the tambour top in towards the end of the project. In this case, I failed the concept of “thinking ahead”. It was not a real hard job, but it is also not a job for a beginner. -- Rich, Cedar Rapids, IA - I'm a woodworker. I don't create beauty, I reveal it. |
Forum | Topics |
Woodworking Skill Share
12027 |
Woodturning
2105 |
Woodcarving
431 |
Scrollsawing
340 |
Joinery
1370 |
Finishing
4903 |
6692 |
28048 |
CNC Woodworking
211 |
Hand Tools
5405 |
Jigs & Fixtures
1417 |
Wood & Lumber
6232 |
1387 |
Focus on the Workspace
2154 |
1186 |
Woodworking Trade & Swap
4754 |
LumberJocks.com Site Feedback
2200 |
Coffee Lounge
8844 |
