How to dry out a log I hollowed out
Forum topic by BradN posted 05-03-2017 05:27 PM 471 views 0 times favorited 5 replies Add to Favorites Watch
View BradN's profile
BradN
31 posts in 881 days
05-03-2017 05:27 PM
I am making a card drop for my daughters wedding. The finished log will be 15” high by 12+” diameter and made from a Sweetgum log.
The log was fresh cut when I started last week, and the wedding is in a month. So I don’t have much time.
What I need to know is what can I do to dry the log as much as possible and keep the bark intact. The wall on the exterior is about an inch.
Thanks for the help
-- Woodworking is the best therapy
5 replies so far
View pontic's profile
pontic
634 posts in 781 days
#1 posted 05-03-2017 05:30 PM
Wrap the bark in tight wet paper and twine and put a small ember fire in the middle of the hollow and flip it over in about 6hrs.
-- Illigitimii non carburundum sum
BradN
#2 posted 05-03-2017 05:48 PM
Is the wet paper on the outside to preserve the bark?
pontic
#3 posted 05-03-2017 08:23 PM
Yes. Don’t exactly know the processes that are going on in the bark. This is the technique my uncle used when he made these things. He hollowed them out with out using a band saw however so I don’t know how that cut will effect things. He then painted the outside with varnish when he was done.
Now mind you I was only 12yrs old when I helped(watched) him do this. Don’t get too big a pile of embers
View HerbC's profile
HerbC
1790 posts in 3032 days
#4 posted 05-03-2017 08:37 PM
While your wife’s away, put it in the conventional oven on very low temp… A few hours should do it…
Good Luck!
Herb
-- Herb, Florida - Here's why I close most messages with "Be Careful!" http://lumberjocks.com/HerbC/blog/17090
BradN
#5 posted 05-03-2017 09:46 PM
I thought of the oven idea, but somehow she always finds these things out.
Thanks
