103" (8'7") Paralok table saw/router fence
Forum topic by Rickles posted 05-03-2017 02:20 PM 949 views 0 times favorited 1 reply Add to Favorites Watch
View Rickles's profile
Rickles
2 posts in 509 days
05-03-2017 02:20 PM
Topic tags/keywords: paralok table saw fence fence table saw
103” (8ft 7in) Paralok table saw/router/shaper fence system. A very sought after fence because how precise they are and since they are no longer in production. It uses cables and pulleys to make sure the fence is always parallel to the table saw blade. If you move the front of the fence a fraction of an inch, the back of the fence moves the exact same. Its VERY wide. has a router/shaper hole at the other end for multi-use system. Its the widest Paralok I could find after doing some research. I also have an older delta table saw I bought off the same guy that took really great care of both, it fits the fence perfectly. I never got a chance to use it because of its size(my shop is small) I wish I had the space to use it! .... $800 for paralok fence. $1,000 for fence and delta table saw. located in cincinnati/dayton Ohio area… for pics or interest. five one three eight five zero eight zero two six
1 reply so far
View Tedison's profile
Tedison
4 posts in 1088 days
#1 posted 05-24-2017 11:28 PM
I was lucky enough to pick up a used Paralok fence a few years ago. Great fence. I am able to get accurate cuts even with my old craftsman table saw. Only downside to a paralok is that it is not easy to remove when you don’t want it on the table for a cross cut.
