Tips for hand tool rip cutting for thinner boards?
Forum topic by DeaconHighlander posted 05-03-2017 02:37 AM 1331 views 0 times favorited 8 replies Add to Favorites Watch
View DeaconHighlander's profile
DeaconHighlander
2 posts in 301 days
05-03-2017 02:37 AM
Topic tags/keywords: hand tools rip cut tips question trick tip
Hello,
I’m looking for suggestions on how to use hand tools (I have/use Japanese tools because I work on the floor, but the concepts should be universal?) to rip cut 8-quarter stock into 1/2” thickness. Thanks!
-- With Abandon, Patrick
8 replies so far
View builtinbkyn's profile
builtinbkyn
1966 posts in 849 days
#1 posted 05-03-2017 03:06 AM
A frame saw is probably the tool to use if you’re going to do it by hand.
There are lots of examples of them on the net.
-- Bill, Yo!......in Brooklyn & Steel City :)
View Ron Aylor's profile
Ron Aylor
2138 posts in 556 days
#2 posted 05-03-2017 10:27 AM
I have found the kerfing plane (rebate saw) to be the key to resawing. The kerf helps keep the rip saw on track.
To date my thinnest resaw is 1/8 of an inch using a No. 8 rip saw.
-- Ron in Lilburn, Georgia.  Knowing how to use a tool is more important than the tool in and of itself.
View Dave Polaschek's profile
Dave Polaschek
1567 posts in 491 days
#3 posted 05-03-2017 10:36 AM
Exactly what Bill and Ron said. Kerfing plane plus frame saw, and you’re set.
-- Dave - Minneapolis
View WayneC's profile
WayneC
13751 posts in 4006 days
#4 posted 05-03-2017 05:05 PM
I think there is a Japanese plane that performs a similar function the a kerfing plane. I’ll have to think about where I saw that.
DeaconHighlander
2 posts in 301 days
#5 posted 05-03-2017 10:59 PM
Thank you, gents! I’ll first try using a gauge as a possible simple way accomplish something similar to the kerfing plane. Given how thin a Royba saw is and the increased control, it may work. Thank you again!
Ron Aylor
#6 posted 05-04-2017 01:43 PM
Thank you, gents! I ll first try using a gauge as a possible simple way accomplish something similar to the kerfing plane. Given how thin a Royba saw is and the increased control, it may work. Thank you again!
- DeaconHighlander
By “gauge” may I assume you are referring to a marking gauge? I’m not sure you’ll get the depth you need with a marking gauge. When I use the kerfing plane for resawing, I’ll set the depth to at least 1/2 inch.
Dave Polaschek
#7 posted 05-05-2017 10:25 AM
A marking gauge can help, especially if you go over the marks with a knife, but a kerfing plane, as Ron points out, gives you a lot more kerf to steer the saw blade. I can usually rip red oak cleanly with only a little wandering using a marking gauge and knife, but I won’t attempt resawing that way. Going to ½” thickness, you might be able to get by with a marking gauge and a knife, but if I were trying it, I’d probably aim for 9/16 or 5/8 and plane down to a half to allow for my wandering saw (and a thin blade can wander more on you).
But heck, give it a try. Best way in the world to learn what works for you and the piece of wood you’re working with.
View Just_Iain's profile
Just_Iain
277 posts in 325 days
#8 posted 05-09-2017 11:54 PM
Here’s a YouTube of someone making a kerfing plane using a Japanese Saw Blade.
https://www.youtube.com/watch?v=XTTzx46z9Bg
Iain
-- For those about to die, remember your bicycle helmet!
