Finger joined Pine - Crown moulding
Forum topic by liamtoh1 posted 05-02-2017 01:45 AM 1151 views 0 times favorited 9 replies Add to Favorites Watch
View liamtoh1's profile
liamtoh1
59 posts in 619 days
05-02-2017 01:45 AM
I am thinking of buying some crown moulding made from finger joined pine from a home center (Menards, Lowes, Home Depot) and installing it myself in formal dining room (and may be others).
Something like this or this.
I will paint them first before installing using glue and nailer (18G) and it will be a first for me (installing any type of moulding).
I would appreciate any thoughts/feedback about ‘Finger-joined Pine’?
9 replies so far
View stan3443's profile
stan3443
301 posts in 2393 days
#1 posted 05-02-2017 02:08 AM
Pine or mdf both work for paint grade. Cut it upside down and cope the corners . crown is an ambishis first project.
-- If your not supposed to have hair on your face......why does it grow their
View TungOil's profile
TungOil
1006 posts in 613 days
#2 posted 05-02-2017 02:11 AM
Finger joints are fine if you are painting. Be sure you read up on how to install crown, it can be tricky due to the compound miters and there are lots of tricks used by trim carpenters to get good results.
-- The optimist says "the glass is half full". The pessimist says "the glass is half empty". The engineer says "the glass is twice as big as it needs to be"
liamtoh1
#3 posted 05-02-2017 03:19 AM
stan3443 and TungOil – Thanks for your feedback. I was worried about the stability of the FJ pine and therefore asked this question.
I plan to first install it in a smaller study room (to gain some experience), before I attempting the installation in the dining room.
View Madmark2's profile
Madmark2
388 posts in 706 days
#4 posted 05-02-2017 04:27 AM
When i apprenticed lo those many many years ago, I had to practice on all the closets. learn how to cope as well as mitered.
FJ pine is absolutely paint grade only. if there are knots you’ll need a sealer coat to stop bleed thru.
M
liamtoh1
#5 posted 05-02-2017 12:43 PM
FJ pine is absolutely paint grade only. if there are knots you ll need a sealer coat to stop bleed thru.
Madmark2 – Thanks for the feedback. Is sealer coat needed for primed moulding?
View 01ntrain's profile
01ntrain
257 posts in 1188 days
#6 posted 05-02-2017 03:44 PM
Normally, there are no knots in FJ pine moulding, so you shouldn’t need a seal coat. If you see any, a coat of clear shellac(just on the knot) will be enough to seal it.
liamtoh1
#7 posted 05-02-2017 03:49 PM
Normally, there are no knots in FJ pine moulding, so you shouldn t need a seal coat. If you see any, a coat of clear shellac(just on the knot) will be enough to seal it.
- 01ntrain
Thanks. Can I paint over shellac or do I need to lightly sand and prime before applying the paint?
Madmark2
#8 posted 05-02-2017 03:56 PM
Pre primed needs no additional prep. Just lightly sand the edges of any sealer to feather it out.
M
liamtoh1
#9 posted 05-02-2017 05:42 PM
Thanks Madmark2
