Why can't you cut ferrous metal with a DeWalt mitre saw (model DW716)?
Forum topic by Sandyegg posted 286 days ago 490 views 0 times favorited 8 replies Add to Favorites
View Sandyegg's profile
Sandyegg
4 posts in 286 days
286 days ago
Hello all.
Have a question…I need to cut a number of powder-coated galvanized steel rails and was thinking about using my mitre saw with an abrasive metal cutting blade by Hilte. I need to get a nice clean cut to finish a project and thought the mitre saw would do a better job than a hack saw. Then I took a look at saw’s manual and it advises against cutting any ferrous material and do not use an abrasive blade. Can anyone tell me why?
Thanks in advance for your responses!
View GaryK's profile
GaryK
8541 posts in 516 days
286 days ago
Good question. Probably a liability thing. Lawyers!
View Thos. Angle's profile
Thos. Angle
3409 posts in 490 days
286 days ago
I have a Makita Chop Saw(for metal) The force I use to cut pipe would wreck my DeWalt chop saw. I wouldn’t try it. Also the steel dust will eat up bearings and make a mess of the inside of your saw. Also, metal will stain some woods. Oh, I forgot to mention all those sparks would not be a good thing in a wood shop.
View Peter O's profile
Peter O
669 posts in 403 days
286 days ago
The arbor might be a different size, too.
You could probably rent a chop saw from a tool rental place pretty cheaply. Or put an abrasive blade on a circular saw.
-- Coffee is best with a fine layer of sawdust on top. -- http://www.north40custom.com
View che's profile
che
123 posts in 554 days
286 days ago
I second the lawyers, of course it could be the marketing department too.
Personally if its a one time deal and if the blade fits (same arbor and outside diameter) and the RPM is close I’d give it a try. Go slow! A one time use won’t kill the bearings. Disconnect it from any dust collection and make sure your not blasting sparks at anything that burns dust/chips etc. Clean the saw well after your done and have fun.
One note: Regardless of how you cut it the powder coating may melt if it gets to hot (~200C). Powder coat powders come in both thermoplastic and thermoset. Thermoplastic will re-melt and thermoset will not. (it may burn if it gets really hot).
-- Che.
View shallnot's profile
shallnot
3 posts in 289 days
285 days ago
I know in the metal shop at work they have a dewalt Mitere saw they use to cut metal. I think mostly Aluminiunum though.
Sandyegg
4 posts in 286 days
285 days ago
Thanks for your comments! I’m going to rent an appropriate chop saw to cut the rails.
Ed from California
View closetguy's profile
closetguy
109 posts in 420 days
285 days ago
I tried that once…and will never do it again. The Dewalt saw has too many plastic parts, such as the throat plate and blade guard. The sparks melted and deformed these parts. A normal metal cutting chop saw has all metal parts and can take the heat. I picked up a cheap 14” chop saw at Lowes for less than $100 to handle this chore.
-- I don't make mistakes, only design changes....
View rick3ddd's profile
rick3ddd
10 posts in 289 days
284 days ago
You do not want to use an abrasive blade. The heat will mess up your poeder coated finish for one and will melt the plastic parts of the saw.
http://www.sussexsawandtool.com/specialty/carbideblades.html
I would use this blade on your saw to cut steel. Works great and doesn’t generate heat or sparks. The technology has been around at least 15 years that I know of
Bookmark And Share This Page
