A better grip....
Forum topic by lilredweldingrod posted 11-09-2010 06:32 PM 2805 views 1 time favorited 30 replies Add to Favorites Watch
View lilredweldingrod's profile
2496 posts in 3042 days
11-09-2010 06:32 PM
Topic tags/keywords: question disabled tool grips clamps
I’m having a problem gripping the slick wooden handles on my clamps. This arthritis is killing my grip. With all the grand kids and bicycles, I cut the old tubes and slipped them over the handles. This worked pretty good until the rubber split and they fell off. lol
I seem to remember years ago there was a liquid that you could dip your tool handles in and get a rubberized grip area on pliers etc. Does anyone know about something like this?
Thanks guys and gals. Rand
30 replies so far
View dbhost's profile
5687 posts in 3167 days
#1 posted 11-09-2010 06:50 PM
The stuff you are asking about is called “Plasti Dip” and it comes in a brush on / dip in can, or an aerosol. The spray doesn’t work all that well… Just do a search on Amazon for Plasti Dip, there are a bunch of varieties. The hard part for you will be to keep the stuff off of the rest of the clamp while it cures. I would suggest masking that off, and then dipping, hanging to dry. I have used this in years past to recoat tool handles with great success.
If you can manage it, you might try drilling the end of the handle, and epoxying in a lag bolt. to the end, that way you can use a socket / ratchet rig to loosen / tighten the clamp. I recall Wood Magazine had a tip about that a couple of years ago…
-- My workshop blog can be found at, YouTube Channel
View sgtsprout's profile
71 posts in 2706 days
#2 posted 11-09-2010 06:51 PM
I found something I seen awhile back. I have used the spray paint version and that did not work too well. I was expected a more rubbery substance. I did not try the dip whcih I imahgine would be much better. Anyway I hope someone can comment or give some type of review. There may be another product out there as well.
A possible option are actual handles as you tried. They might get too pricy though.
I am not affliated with any of these companies just did a quick search and this is what came up.
-- "There are no gains without pains." -Benjamin Franklin
16273 posts in 4154 days
#3 posted 11-09-2010 06:56 PM
Their website says it is available at Ace hardware stores.
View Roger Clark aka Rex's profile
Roger Clark aka Rex
6940 posts in 3370 days
#4 posted 11-09-2010 06:57 PM
Also look on Amazon
-- Roger-R, Republic of Texas. "Always look on the Bright Side of Life" - An eyeball to eyeball confrontation with a blind person is as complete waste of Time.
View Joe Lyddon's profile
Joe Lyddon
10012 posts in 3988 days
#5 posted 11-09-2010 07:00 PM
Hey Rand…
You know that special rubber mat stuff you can Route on?
The stuff that holds the piece in one place!
I usually have a piece of it handy… Just wrap a corner around the clamp and Turn It… no pain or strain!
-- Have Fun! Joe Lyddon - Alta Loma, CA USA - Home: ... My Small Gallery:"
View racerglen's profile
3112 posts in 2716 days
#6 posted 11-09-2010 07:02 PM
Another answer I’ve seen is to take a wood gouge and cut groves in the handles length ways
providing a better grip.. or a wood plane could make flats as well.
-- Glen, B.C. Canada
View JJohnston's profile
1622 posts in 3227 days
#7 posted 11-09-2010 07:13 PM
Other possibilities:
Turn some new handles with bigger diameter – this will give you more leverage/more torque.
Cut wrench flats into the handles and use a big crescent wrench.
Drill cross-holes thru the handles and use a long steel pin for leverage.
-- "A man may conduct himself well in both adversity and good fortune, but if you want to test his character, give him power." - Abraham Lincoln
View Jim Bertelson's profile
Jim Bertelson
4162 posts in 3100 days
#8 posted 11-09-2010 07:16 PM
To second what others have said, don’t use the spray Plasti-Dip, you need the liquid, and you actually dip the whole handle in it. I did that for some hold downs, although I haven’t abused them yet…..........
-- Jim, Anchorage Alaska
View Gene Howe's profile
Gene Howe
10264 posts in 3364 days
#9 posted 11-09-2010 07:52 PM
Hey Rand,
Take a look here. GripWrap
View traupmann's profile
124 posts in 2723 days
#10 posted 11-09-2010 08:04 PM
I bought some at Home Depot called Plastic Dip. I coated several things—took a couple of dips to get a usable coat, but it worked.
-- chas -- looking for Serta sponsorship to go Pro...
View rance's profile
4255 posts in 3096 days
#11 posted 11-09-2010 08:10 PM
Hockey Stick Tape. This idea comes from Rob Cosman. He swears by it.
#12 posted 11-09-2010 08:16 PM
WOW! Talk about, “Ask and you shall receive.”! Thanks and that was fast! I know it is a well worn cliche, but you guys are the best. Thanks again, Rand
PS I have info coming and even samples! Thanks again.
Jim Bertelson
#13 posted 11-09-2010 08:21 PM
Both the GripWrap and the hockeystick tape sound like good solutions, probably cheaper than Plasti Dip, but not as pretty. You into pretty?..............(-:
#14 posted 11-09-2010 08:59 PM
Jim, Am I into “pretty? Evidently you haven’t noticed how gorgeous I am. lol I’m a legend in my own mind.
When I inquired of some of the suggestions I received here, they were offering samples, so they are on the way.
I really like the hockey stick tape idea. I’ll run over to Big 5 Sporting Goods and see what they have.
And Joe I need a couple of those pads anyway.
Thanks again to all for your suggestions. I repeat, YOU ARE THE BEST. Rand
View Dennisgrosen's profile
10880 posts in 3051 days
#15 posted 11-09-2010 09:22 PM
drill a hole and use a dovel
or make the last ½inch square and make a wrench with a square hole out of baltic birc plywood
make five of them then there shuold be a chance to find one when needed…lol
Take care
showing 1 through 15 of 30 replies
