Look into for a front knob replacement
« back to Hand Tools forum
Forum topic by Walt posted 04-30-2017 10:57 PM 696 views 0 times favorited 12 replies Add to Favorites Watch
View Walt's profile
Walt
250 posts in 3077 days
04-30-2017 10:57 PM
Topic tags/keywords: question plane
Anyone have a good source to get plane handle replacements?
-- Walt Wilmington Delaware, http://waltlumley@yahoo.com
12 replies so far
View bandit571's profile
bandit571
22006 posts in 2922 days
#1 posted 04-30-2017 11:32 PM
nhplaneparts…..on ebay
View Woodmaster1's profile
Woodmaster1
1089 posts in 2826 days
#2 posted 04-30-2017 11:59 PM
You could make a front handle on a lathe
View Walt's profile
Walt
#3 posted 05-01-2017 12:44 AM
I could but would rather replace both the handle and the tote
View corelz125's profile
corelz125
589 posts in 1215 days
#4 posted 05-05-2017 01:43 AM
there is a lot of front knobs on ebay right now
View JohnChung's profile
JohnChung
416 posts in 2313 days
#5 posted 05-05-2017 03:13 AM
I made a review for handle and knob replacement. Really happy with the choice I made.
http://lumberjocks.com/reviews/3866
View HorizontalMike's profile
HorizontalMike
7770 posts in 3153 days
#6 posted 05-05-2017 01:46 PM
What do you have?
View Walt's profile
Walt
#7 posted 05-05-2017 02:27 PM
Mike it is a #3 bench plane I can find no marking in the framework or frog
View JCamp's profile
JCamp
893 posts in 789 days
#8 posted 05-05-2017 02:44 PM
Unless you are wanting to keep it “Original” id say your two cheapest options are:
1 – Make your own, which is very time consuming
2 – go buy a cheap plane from HF for around $8 and steal the parts from there
Seems like Ebay wants as much for the handles as a plane is worth
-- Whatsoever thy hand findeth to do, do it with all thy might
View Walt's profile
Walt
#9 posted 05-05-2017 03:44 PM
I think I will take th HF option the turning option is not a problem but I have two other projects going and don’t want to spend the time prepping a blank and turning a knob that will fit
HorizontalMike
#10 posted 05-05-2017 10:44 PM
- Walt
Walt, I mess around with around with Sargent hand planes. That said, I can replicate most Sargents, IF the tote & knob threading has not been bastardized into something like a 1/4-20 (more frequent than one would think). I can probably replicate the steel shafts (13/32”) AND BRASS IF you now exactly what you need. IF the threading has been changed, then I need to know that in order to make adjustments.
Bottom line, if you can and know what you need, then do the eBay thing to acquire what you need. I am not into profiteering, but do understand that one-off parts get expensive quickly. send me an email at mike at horizontalheavens dot com and lets talk.
View Walt's profile
Walt
#11 posted 05-05-2017 11:27 PM
Mike thanks for the offer but I think I will try to turn it, I found a piece of walnut that shoul work will post results if it works out.
HorizontalMike
#12 posted 05-06-2017 12:46 AM
- Walt
Cool! Rather a DIY, if you can, anyway… 8-)
