| Forum topic by yellowtruck75 | posted 952 days ago | 2338 views | 0 times favorited | 12 replies | ![]() |
952 days ago |
I want to start attempting Windsor chairs but a necessary tool that I need is a steam box. I have been looking around at people’s home made steam boxes and at ones that I can buy. It seems that to get it right it is expensive to build. The one that I am looking to buy is Mike Dunbar’s on thewindorinstitue.com website (not a student so have to pay higher price). If I opt for the entire package its $375 but removing the saw buck and the burner it takes it down to $255, which isn’t to bad. So the question I am asking myself is, is it worth to spend the money and know its build correct or attempt it on my own and possibly get it wrong. What have others done and/or suggest. I know that is hard to discuss since everyone is in different financial positions but I am looking at this from the perspoective of getting it right and have it work flawless. |
12 replies so far
#1 posted 952 days ago |
When it gets down to something that is really safety related, (like what isn’t in woodworking) I buy it. I have some pics of one I downloaded off the web. It’s not my project, not my pics, so I won’t post them here. -- It must be jelly baby, cause jam don't shake like that... |
#2 posted 952 days ago |
I can’t tell you which way to go but here is a link to one by American Woodworker: http://americanwoodworker.com/blogs/shop/archive/2009/07/09/simple-steam-box.aspx -- - Eric Indianapolis, IN |
#3 posted 952 days ago |
hairy I have the thoughts about safety and buying vs building. With a steam box I could cause alot of damage if its not properly built. |
#4 posted 952 days ago |
I have scrounged 6” galvanised pipe for mine and will use a steam kettle with auto boil dry shut off . -- A mind, like a home, is furnished by its owner |
#5 posted 952 days ago |
#6 posted 952 days ago |
i made one out of PVC pipe. Works really well actually. I made sure it was set up on a slight angle, and a hole towards one end on the bottom to let out the hot water (and pressure) that forms inside. If the hot water has a way of escaping and some of the pressure can be relieved, steam boxes are pretty safe. Just have to make sure you wear gloves, long sleeves, and keep your face back when opening up the door so the steam doesnt hit you and burn you! there are TONS of designs online. I would say building one is the best option. i built my PVC one for like $15. Granted it doesnt hold many pieces at a time (but i didnt need that). I would imagine you could build one that is custom built to your needs for WAY less than $255. -- Hey you dang woodchucks, quit chucking my wood!!!! |
#7 posted 952 days ago |
I have a steam box made from ABS pipe and fittings and it works well and is cheap. Just select the diameter of pipe you need to accommodate the projects you intend to undertake. The Lee Valley (Veritas) directions will provide all else you need. -- DonH Orleans Ontario |
#8 posted 952 days ago |
When I had my shipyard, I used an industrial steam cleaner with the water pump disconnected and a few other mods. It fed a box that was about 25’ long and made out of an old piece of about 18” diameter wooden pipe. It would steam two inch planks in about 30 minutes. When I needed a portable unit later I built this one for free. -- Paul M ..............If God wanted us to have fiberglass boats he would have given us fiberglass trees. http://prmdesigns.com/ |
#9 posted 952 days ago |
The price seems pretty high for something that simple. There isn’t much to it, and so long as your steam source is safe, the box shouldn’t be a problem. -- Nate, thegaragestudio.etsy.com |
#10 posted 952 days ago |
It might be worth adding that the steambox issue is only half of the problem, the other half being how you gotta find straight-grained logs and split them, following the splits the way the log wants to split, and carefully hewing your own raw pieces to steam-bend. You can’t just use dressed lumber for this, and expect good results. -- Einstein: "The intuitive mind is a sacred gift, and the rational mind is a faithful servant. We have created a society that honors the servant and has forgotten the gift." I'm Poopiekat!! |
#11 posted 952 days ago |
yeah air-dried lumber, with straight grain is KEY to a good steam bent piece of lumber. Its very hard (close to impossible) to steam bend kiln-dried lumber. good luck! let us know what you decide -- Hey you dang woodchucks, quit chucking my wood!!!! |
#12 posted 952 days ago |
I looked at the links. I guess I’m in the wrong ballpark. Those tea kettle arrangements will take a long time but I guess on small pieces they will work. Pressurized steam ie: 225deg.F is faster and penetrates better, but again I guess on small pieces it isn’t required.. I will pass on my steam bending do’s though. In case it doesn’t come up elsewhere… 1) bend on the flat grain, that is on the inside and outside of the curve. 2) take a little chamfer off the corners to prevent running splinters that can ruin the whole piece. 3) Good grain is important but it needn’t be perfectly straight. 4) Can’t be “kill” dried. -- Paul M ..............If God wanted us to have fiberglass boats he would have given us fiberglass trees. http://prmdesigns.com/ |
| Forum | Topics |
Woodworking Skill Share
8846 |
Woodturning
246 |
Woodcarving
32 |
Scrollsawing
69 |
Joinery
96 |
Finishing
1599 |
3593 |
15978 |
Hand Tools
2095 |
Jigs & Fixtures
501 |
Wood & Lumber
2906 |
813 |
Focus on the Workspace
925 |
778 |
Woodworking Trade & Swap
2776 |
LumberJocks.com Site Feedback
1553 |
Coffee Lounge
6133 |
