Solid Wood or Veneered Plywood?
Forum topic by ProutyBoy posted 160 days ago 237 views 0 times favorited 9 replies Add to Favorites
View ProutyBoy's profile
ProutyBoy
7 posts in 160 days
160 days ago
Topic tags/keywords: question
I will be building some custom shelves for a client soon and am wondering whether I can use solid wood for the build or if I should stay on the safe side and use plywood with a banding. The design will be a set of interlocking “c” shapes each being about 50” long by 18” tall and 5” deep. For strength and aesthetics, I plan on the shelves being about 1.25” thick. I am wondering about movement in kiln dried lumber. They will probably be made from oak, cherry, or curley maple. Do you think that’s too long to go with solid wood?
Here is the basic design:
Also, as far as mounting them, I was thinking about keyholes set at 45 degrees so they can be mounted on the vertical and horizontal edges and hit the studs. Anyone know of something that might be stronger than that but still be removable in case they want to move or redesign the system?
View GaryK's profile
GaryK
8250 posts in 390 days
160 days ago
I have a question. Where would you find 1.25” think plywood?
ProutyBoy
7 posts in 160 days
159 days ago
I would laminate two pieces if I went with plywood and then edge band them.
BTW: I grew up in east TX. Hughes Springs to be exact.
View Mario's profile
Mario
696 posts in 453 days
159 days ago
I agree with ProutyBoy about the plywood and edgebanding. I do have a question though, how will they be secured to the wall.?
-- Hope Never fails
View Peter O's profile
Peter O
622 posts in 276 days
159 days ago
I think I’d lean toward solid wood. If it’s properly kiln dried, 1¼” thick, jointed flat, then I don’t think it’s going anywhere. Additionally, I don’t think I would trust keyhole slots in the edge of plywood.
I saw plans for this style of shelves somewhere (too many magazine subscriptions), but I don’t remember how they attached the shelves to the wall. You’d need a bunch of keyholes, and getting the screws in the right spots in the wall would be a challenge.
-- What exactly is "The Move" and who are you calling a "Quirky Jerk"? -- http://www.north40custom.com
View EaglewoodsPres's profile
EaglewoodsPres
22 posts in 132 days
132 days ago
I would vote the plywood method. Laminate to your 1 1/4 thickness and band it. As far as the mounting method. I have used, to some sucess, a metal rod technique. 1/2” metal rods drilled into the studs and epoxied in place. Corresonding holes drill 3/4 of the way into the shelves hold the weight. Out of sight and sturdy. The one drawback to this method is the layout. You almost have to temporarily hold the unit to the wall, level it, and carefully mark where the holes need to be on the wall and on the shelf. Very labor intensive.
-- Chris ( Eaglewoods@sbcglobal.net )
View Joe Lyddon's profile
Joe Lyddon
126 posts in 454 days
124 days ago
I also vote for the Plywood…
Laminated ply would a WHOLE LOT stronger than solid wood, could be butt glued, if desired, and it would be very strong. Whatever joint was used would be covered by the edge banding.
BTW, very nice design… have never seen it before… COOL!
-- Have Fun! Joe Lyddon - Home: http://www.WoodworkStuff.net ... My Small Gallery: http://www.ncwoodworker.net/pp/showgallery.php?cat=500&ppuser=1389"
View cpt_hammer's profile
cpt_hammer
70 posts in 214 days
123 days ago
I recently was looking through a magazine on storage solutions and they rated solid wood as stronger than plywood for bookshelves. They said you can safely load 36” of solid wood shelves with books assuming 25lbs/ft load weight and only 30” with plywood. which one is correct? They also showed a couple of ways you can increased the strength of plywood by applying a solid wood front edging and other methods to strength shelves.
View SPalm's profile
SPalm
668 posts in 284 days
123 days ago
If it was me doing it, I would go with plywood and edge banding.
My first thougt for attaching it was a french cleat, but that would show. I don’t think getting those keyholes to line up would be very much fun at all. I have seen some hidden mount shelves like this that use a metal plate with pins/rods sticking out that is attached to the wall. These pins and the plate fit into holes and a routed recess in the back of the shelves. You just push the shelves on and secure with a small screw from the bottom. Kind of like what Chris was describing. It’s got to be strong though.
Steve
View brianinpa's profile
brianinpa
253 posts in 125 days
123 days ago
I would go with the plywood. I like the idea of doubling it up, as a book shlelf the length you are looking at, 3/4” may begin to bow ill not supported at every stud. Also I don’t think the keyholes are the right way to go for mounting it. I have seen the pin method mentioned above by Chris and Steve, and as long as you do not live in an earthquake prone area, the shelves will stay right where you want them.
Bookmark And Share This Page
