Pizza peel finish
Forum topic by patcollins posted 11-09-2010 03:37 AM 2528 views 0 times favorited 4 replies Add to Favorites Watch
View patcollins's profile
patcollins
1658 posts in 2773 days
11-09-2010 03:37 AM
What would be safe finishes to use for a pizza peel finish? I have mineral oil that I use on a cutting board but was thinking of something like shellac. I made a nice one from red oak and want a protective finish on it that can take the heat of a pizza as some pizza goop without staining. I’d like the finish to be a satin sheen.
Would polyurethane be ok also?
View richgreer's profile
richgreer
4541 posts in 2982 days
#1 posted 11-09-2010 03:49 AM
Shellac cannot stand up to heat or moisture. Otherwise, it would be great for a pizza peel.
View araldite's profile
araldite
188 posts in 3311 days
#2 posted 11-09-2010 03:57 AM
I’m not sure that pizza peels have any finish on them, but I would probably go with a common salad bowl finish.
-- Failure is the road to success if you learn to learn from your mistakes - Vince, Greenville, SC
View firecaster's profile
firecaster
571 posts in 3326 days
#3 posted 11-09-2010 06:30 AM
Mineral oil is what I used on mine.
-- Father of two sons. Both Eagle Scouts.
View barryvabeach's profile
barryvabeach
159 posts in 2951 days
#4 posted 11-09-2010 02:51 PM
+1 on the mineral oil. Dust it with cornmeal when you put the pizza on it, and it will slide easy.
