| Forum topic by Big Ben | posted 928 days ago | 1441 views | 0 times favorited | 4 replies | ![]() |
928 days ago |
Topic tags/keywords: plane iron hand plane plane grinder grinder wheel refurbishing milling I currently have a plane iron, Millers Fall Jack, where the bevel is not 90 degrees. Its about 12 degrees off. So I got myself a bench grinder (Ryobi 8”), I plan on purchasing a white oxide grinder wheel to grind the bevel straight and put a heavy camber on it. So my question is what is the best grit to get? Also if you have any jigs suggestions for holding the iron or puttnig the camber on the iron. Or what is the best angle to grind to I would love the help. Thanks. |
#1 posted 928 days ago |
I do not sharpen with grinder, I cannot tell you what grit stone to get.
The bevel you will need on your iron will depend on the type of plane you are sharpening. For example if your plane has a 45 degree angle , anything under 45 degrees is acceptable. (Enough to keep the heel of iron from touching wood) Typicaly 35-40 degrees. The thicker the bevel the longer it should stay sharp. Provided there is a good iron in it to begin with. There are low angle planes.
-- "My mission in life - make everyone smile !" |
#2 posted 928 days ago |
Get the most coarse grit you can, probably 36. You don’t need a white wheel or the other expensive wheels, you’re grinder likely came with a wheel that’ll work fine. Get a wheel dresser and keep the surface fresh and true. Layout the shape of the iron you want, I suggest a 12” radius or so. Grind initially at 90º to the face of the iron to establish where your new cutting edge will be. Then grind the bevel and I suggest a 25º bevel. You’ll be able to watch the flat under the edge disappear as you grind the bevel. Grind lightly when this flat goes a little beyond half way gone. Keep the wheel’s surface fresh with the dresser as you proceed to where you only have a hair line of that flat left. Then hone at 30º. |
#3 posted 928 days ago |
At the risk of offending some of the hand tool purists here, I would suggest using a belt or disk sander for the initial stages of grinding. The powered sanding tool will be a big help to correct a 12 degree bevel error. -- Michael :-{| Diapers and politicians both need to be changed often; and for the same reason. |
#4 posted 928 days ago |
Just for clarity, I will only be grinding to get the primary bevel. I will be hone the bevel with 1000, 4000 and 8000 grit water stone. |
| Forum | Topics |
Woodworking Skill Share
8798 |
Woodturning
224 |
Woodcarving
28 |
Scrollsawing
61 |
Joinery
82 |
Finishing
1538 |
3556 |
15816 |
Hand Tools
2039 |
Jigs & Fixtures
496 |
Wood & Lumber
2847 |
810 |
Focus on the Workspace
903 |
766 |
Woodworking Trade & Swap
2742 |
LumberJocks.com Site Feedback
1547 |
Coffee Lounge
6166 |
