Attaching Rare Earth Magnets
Forum topic by Peter O posted 286 days ago 211 views 0 times favorited 8 replies Add to Favorites
View Peter O's profile
Peter O
669 posts in 403 days
286 days ago
Topic tags/keywords: rare earth magnets attach glue epoxy
I’ve meant to do do work with rare earth magnets before, but never really had a reason until now. I’ve attached metal items to wood before, and had good luck with silicone adhesive and poly glue. But I’ve tried both the silicone and the poly, and neither seems to stick to the magnets. I haven’t tried epoxy yet. What do you guys use?
-- Coffee is best with a fine layer of sawdust on top. -- http://www.north40custom.com
View Ryan Shervill's profile
Ryan Shervill
199 posts in 341 days
286 days ago
I use a lot of magnets…in fact, just in the last ten minutes I’ve installed 16 of them, from 1/8” X 1/8” up to 1” X 1/8” for a jig series I’m doing for Canadian Home Workshop magazine. Not knowing what your sizes and applications are, i’ll give you both methods:
1: Small magnets (3/8” or smaller) Clean the magnets well with a solvent. I like brake cleaner, but mineral spirits or alcohol will work.
rough up the glued side slightly with 220 grit paper, and glue in place with 5 minute epoxy.
2: If you are using the larger magnets (1/2” – 1”), because of their strength, the best method is to secure a like-sized washer to the wood with a screw that sits flush with the surface of the washer, apply some epoxy to the washer, and stick the magnet in place (treating the magnet the same with the solvednt/paper).
This will hold pretty much forever, and backing the magnets with steel actually increases their strength as well.
Hope this helps.
Ryan
-- If you can't set a good example, at least serve as a horrible warning... www.rarewoodcreations.com
View GaryK's profile
GaryK
8541 posts in 516 days
286 days ago
I agree with Ryan.
View rikkor's profile
rikkor
8362 posts in 403 days
286 days ago
Thanks Ryan for the “how-to”. I have some 3/4” by 1/8” that are really aggressive. I’ll be using your advice.
-- Maplewood, MN
View Recycler's profile
Recycler
40 posts in 293 days
286 days ago
I’d never thought of the washer+epoxy approach—only one or the other. Nice tip.
View Harry72's profile
Harry72
49 posts in 295 days
286 days ago
Cool tip on the washer!
Thx mate.
Peter O
286 days ago
Thanks for the great advice, Ryan! I’ll give it a try again today.
For some reason, I always try new techniques on gifts. Most gifts have a very specific deadline, and when the new technique doesn’t work as planned, then I’m in trouble! Fortunately I still have a couple of days!
View Thos. Angle's profile
Thos. Angle
3409 posts in 490 days
286 days ago
I’ve been insetting them and using 2P-10 to hold them. Seems to work so far. I like Ryan’s method as well.
View Jim Crockett's profile
Jim Crockett
99 posts in 261 days
261 days ago
Another method is to use the cups available for most sizes of the disk magnets. It increases the power of the magnet considerable and give you a metal-to-metal glue surface. The cup can be inset into a correct sized hole drilled with a fostner bit or surface mounted. I think that Rockler sells the cups, if not you can get magnets and hardware at http://www.kjmagnetics.com/categories.asp?cat=86.
JimC
Bookmark And Share This Page
