? ABOUT G0538 Spindle Sander
Forum topic by GR8HUNTER posted 04-29-2017 03:00 PM 571 views 0 times favorited 9 replies Add to Favorites Watch
View GR8HUNTER's profile
GR8HUNTER
4007 posts in 741 days
04-29-2017 03:00 PM
Topic tags/keywords: question sander
I own this sander ….. was wondering if I have to buy the sleeves from Grizzly ($65.00) for 1 grit LMAO :<)) .......or is there another source out there …...that I am overlooking …..I did buy some somewhere else off internet …......BUT sleeves do not fit my drums …....THANKS 4 HELP :<))
9 replies so far
View Robert Keeney's profile
Robert Keeney
85 posts in 3541 days
#1 posted 04-29-2017 03:19 PM
Google for “4.5 inch sanding sleeves” should give you smome options. I find that I have to buy from one of the abrasive specialist if I want to buy a lot of one grit otherwise I get a lot of sleeves that I will never use.
-- Robert in Tallahassee Florida, http://OdinsToyFactory.com
GR8HUNTER
#2 posted 04-29-2017 03:28 PM
NOT SO much the length as Diameter that is the problem
View Dutchy's profile
Dutchy
2989 posts in 2196 days
#3 posted 04-29-2017 03:38 PM
View lew's profile
lew
12102 posts in 3783 days
#4 posted 04-29-2017 04:42 PM
Take a trip over to “Super Grithttp://www.supergrit.com/” in Gettysburg. I buy all mine there.
View ralbuck's profile
ralbuck
4589 posts in 2294 days
#5 posted 04-29-2017 06:30 PM
I have not used H-F’s sanding sleeves; but have bought their sanding belts for years. When i first had a belt sander I bought belts from the normal (Lowe’s H-D Sears-etc.) suppliers. One time I bought H-F belts just to try them as the others were gobbling up my non-existent budget. They lasted better than the ones I had previously bought. I have purchased my sanding belts from them ever since.
When i need sleeves or belts for my Grizzle spindle/belt sander I am going to try H-F for those too. http://www.harborfreight.com/80-grit-sanding-sleeves-6-pc-60605.html
They do have several other grits available too.
-- Wood rescue is good for the environment and me! just rjR
View Sawdustmaker's profile
Sawdustmaker
295 posts in 3825 days
#6 posted 05-08-2017 12:31 PM
Have you checked Wood Craft?
-- Brian, Virginia Beach
GR8HUNTER
#7 posted 05-08-2017 01:41 PM
was going to call them today my drums are OD …so this requires sleeves to be 1 inch ID …and I have the sleeves that are 1 inch OD :<((
GR8HUNTER
#8 posted 06-01-2017 03:13 PM
UPDATE I found the correct ones at Harbor Freight ….NOW I just hope they hold up well :<))
China sandpaper for a China sander LMAO :<O
View cebfish's profile
cebfish
156 posts in 2716 days
#9 posted 06-01-2017 03:40 PM
I have the HF model sander I bought my sleeves from Klingspors. I have been using the same set for about 2 years and they still sand very well
