question about smoothing a glued up game board
Forum topic by jred posted 11-08-2010 10:23 PM 992 views 0 times favorited 7 replies Add to Favorites Watch
View jred's profile
jred
49 posts in 3069 days
11-08-2010 10:23 PM
I have come across a game from South America involving some wood pieces and a 16 squared board. I had some cherry scraps sitting around and decided to make my own copy. Well, two actually. I sliced the cherry strips in half and glued up two 8×8 x 1/2” thick game boards with maple strips in between the squares (make sense? Think a checkerboard with only 4 squares on each side). Glue ups went fine and everything lined up really well. I attempted to smooth the boards down by running them through the planer which is where the trouble began. I attempted to take off about 1/64th on the planer and the first board went through ok. The second got stuck inside and was completely destroyed. I ran the first board through again to take off another 64th and it too was pretty badly mangled. Not a huge deal. Like i said, it was just made of scraps, but i’d like to make a nice one of these to give as a Christmas present this year and wanted to know if anyone had any suggestions for smoothing the top of one of these boards after the glue up? Am I just using the planer wrong or do you really have to have a minimum length of piece in order to use one safely?
thanks
7 replies so far
View Szczuldo's profile
Szczuldo
42 posts in 2678 days
#1 posted 11-08-2010 10:51 PM
if i remember correctly from my readings most planers have a minimum length of board which can be feed through, I assume so it does not get stuck between the rollers. I do not yet have one of my own, only been drooling over what i want so far, so I could be missing something.
-- -Alexei
View chrisstef's profile
chrisstef
17167 posts in 2910 days
#2 posted 11-08-2010 11:03 PM
Id assume that its too small to send through the planer, sounds like it got hung up on the rollers or the snipe got ya. I know a lot of people make a planer sled to accomodate short pieces or even cupped pieces. You could try using card scrapers to take it down some. They’re fairly cheap $15 or so.
View DrDirt's profile
DrDirt
4421 posts in 3646 days
#3 posted 11-08-2010 11:19 PM
I think the piece is a bit on the small side. I have run 8 inch pieces through my planer (Dewalt 735) and I think most ‘Lunchbox’ style planers would be ok. I think it is the combination of being both short and rather thin that is causing the problems.
If it were a thicker piece, there would be less tendency to bounce or flex when only held by one roller because the cutter wants to ‘lift’ the front edge of the board and chew it up.
When I do thin strips I put them down with doublestick tape on a carrier board. I have a piece of the white melamine coated particle board from one of those 12 dollar ‘closet shoe organizers’ from the Borg.
View richgreer's profile
richgreer
4541 posts in 2978 days
#4 posted 11-09-2010 01:49 AM
This sounds like the job for a sander. First choice – drum sander. However, a belt sander or ROS would also do the job.
View SPalm's profile
SPalm
5315 posts in 3786 days
#5 posted 11-09-2010 01:57 AM
I would go with Rich. Abrasive thicknessing. Blades sometimes hate multi wood glue-ups.
Steve
-- -- I'm no rocket surgeon
16272 posts in 4122 days
#6 posted 11-09-2010 02:05 AM
Multi grains and different grain directions can play heck with a planer. But when the only problem is a piece being too short, you can work around it by sending a similar-thickness longer scrap board through the planer directly behind and butting up to the shorter board.
View shipwright's profile
shipwright
7894 posts in 2702 days
#7 posted 11-09-2010 03:51 AM
I like Rich and Steve’s plan – sanding. However if you don’t have too far to go my first choice would be a scraper and no (or very little) sanding. It might stay flatter…unless you have a drum sander.
