Making a small notch in the lid of a box
Forum topic by grace123 posted 11-08-2010 08:47 PM 1197 views 0 times favorited 8 replies Add to Favorites Watch
View grace123's profile
grace123
235 posts in 2787 days
11-08-2010 08:47 PM
How is the best way to make a small thumb notch in the lid of a small box? I am making several boxes of my left over scraps into decorative boxes for business cards, etc.
8 replies so far
View rance's profile
rance
4258 posts in 3186 days
#1 posted 11-08-2010 09:02 PM
Using the yools you already have. :) Seriously(still) Do you have a spindle sander, stationary belt sander, portable belt sander, paint can & a piece of sandpaper? Any of these would work. Some work better than others. The ones you have work better than the ones you don’t. :) Hope this helps.
View MrsN's profile
MrsN
986 posts in 3551 days
#2 posted 11-08-2010 09:09 PM
I would probably sand a notch in to the lid using a dremel, or wrap a piece of sand paper around a small dowel.
View HallTree's profile
HallTree
5664 posts in 3792 days
#3 posted 11-08-2010 09:10 PM
What type of lid, sliding, hinged, removable?
-- "Hold on to instruction, do not let it go; guard it well, for it is your life" Solomon
grace123
#4 posted 11-08-2010 09:19 PM
I should have mentioned that the box will hinged with a hidden knuckle hinge on the inside.
View SCOTSMAN's profile
SCOTSMAN
5849 posts in 3610 days
#5 posted 11-08-2010 09:59 PM
Try this set the box at an angle with a home made jig secure the box under a drill press and use a forstner bit of correct size try a few blanks for short time till you get it perfected then, fire away .Alistair
View Jim Crockett (USN Retired)'s profile
852 posts in 3758 days
#6 posted 11-09-2010 05:41 AM
I use a table-mounted router with a core box bit. You will get some burning but it creates a nicely shaped finger relief.
Jim
-- A veteran is someone who, at one point in his/her life, wrote a blank check made payable to "The United States of America," for an amount of "up to and including his/her life".
HallTree
#7 posted 11-09-2010 05:28 PM
When I read Mafe’s post ‘Cubistic grease box (rare earth magnets lock and hinge) now he lost it!’ I thought of your lid on your small box.
View KayBee's profile
KayBee
1083 posts in 3271 days
#8 posted 11-09-2010 07:11 PM
Sharp knife and carve one out. It’s what James Krenov did. Nice tactile feedback(okay, it feels nice) and no dust.
-- Karen - a little bit of stupid goes a long way
